Results 1 to 17 of 17
Thread: Skip shift questions...
12-29-2006, 09:55 PM #1
1. Is there any skip shift eliminator that you can install without going under the car?
2. Is there a particular brand I should get, or do they all work the same?
Thanks.
12-29-2006, 10:19 PM #2
well, for question 1-i dunno. #2 you can get some stuff from summit racing or jegs or something. or you can go to installuniversity.com and do it yourself from radioshack for like $2.00
12-29-2006, 10:20 PM #3
o yea, welcome to the board
12-30-2006, 06:53 AM #4
- Nov 2006
- Earth
I would think if you can find the particular wires that run to the transmission for the CAGS then you could cut them and place the 2200 ohm resistor across the wires running to the pcm. A wiring diagram might show you which these are. You may then find them behind a kick panel or in the bundle leading directly to the pcm from the firewall.
It is so much easier to lift the car on one side, find the Dexron III sticker on the transmission, unplug the connector, insert resistor and tape it all up but you must have a good reason for not being able or wanting to get under the car.
12-30-2006, 07:10 AM #5
1. handheld tuner. full on tuning suite. delete the CAGS.
12-30-2006, 07:30 AM #6
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
$30 product from a sponsor which eliminates it, or .99 cent resistor from Radio Shack which does require you to get under the car and pull a plug out.
12-30-2006, 07:51 AM #7
- Oct 2006
- St. Clair Shores. Michigan
Ther use to be Free Mod links on this site way back that showed how to due the resister mod. I bought 6 resisters for 49 cents back in `99 did 3 cars with it including my own and have never had a problem since. Takes 5 min once you get the Car up.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
12-30-2006, 07:56 AM #8
DiabloSport Tuner
I used the Predator DiabloSport Tuner and deleted.
12-30-2006, 09:54 AM #9
So, a few people mentioned a hand held tuner. I have the Hypertech PP3, but they don't make any mention of "skip shift" in the manual. Maybe I'll give them a call after the holiday, unless someone knows for sure that it won't work.
12-30-2006, 10:19 AM #10
- Jul 2005
- Jacksonville, FL
Don't think HPP3 will do it, but haven't used one in years.
12-30-2006, 10:35 AM #11
I just looked at the Hypertech PP3 ads and they don't list CAGS as one of their options.
12-30-2006, 12:09 PM #12
I coughed up the $30 to RKSport about 5 years ago and haven't had a problem since. It gives you a weatherpack OEM type sealed conection. By all means if you still have skip shift hooked up-get rid of it. I couldn't stand it-even though I only drove with it for a month or so.
12-30-2006, 12:44 PM #13
- Nov 2006
- Earth
01-01-2007, 06:21 AM #14
Bought a kit from ebay and it turned out to be the .59cent resistor and one page of instructions which I later found I could get off install university.Git a little pissed whenever I think about it,but hey,didn't do my homework on the subject.And love the way it drives now!
If you don't want to get under the car I think the only way is to turn it off with a tuner and since I just installed a Hypertech III,I know it won't do it.
01-01-2007, 08:38 AM #15
http://www.installuniversity.com/ins...r/cags_slp.htm Buy a jack/jackstands and hook it up.
01-03-2007, 09:53 PM #16
- Burlington, NC
Black- 2000 Camaro SS
SLP and AFTERTHOUGHTS AUTO both sell a SKIP SHIFT ELIMINATOR.
01-05-2007, 03:53 AM #17
- MA
Black- 2002 WS6
I bought this a while back as I wanted the weather pac connector:
http://www.jegs.com/webapp/wcs/store...46161_-1_11187
The cheap radio shack fix works just as good.
Skip Shift
By 10erg01 in forum Manual TransmissionReplies: 1Last Post: 12-11-2010, 10:22 PM -
Skip shift
By Method in forum General HelpReplies: 18Last Post: 03-23-2008, 09:42 AM -
....skip-shift...
By champain in forum Computer & TuningReplies: 13Last Post: 02-08-2008, 04:30 PM -
$0.99 skip shift
By BLKbandit98 in forum Firebird / WS6Replies: 9Last Post: 04-11-2006, 07:21 PM -
skip shift
By smurf69 in forum General HelpReplies: 11Last Post: 09-22-2005, 02:21 PM
