Results 1 to 20 of 22
Thread: pulley noise
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    pulley noise
    So....I started noticing a noise today,I diagnosed the tensioner pulley,removed the pulley and sure enough when I held the pully in my hand and shook it,it rattled,so I walked to advance auto parts and purchased a new tensioner pulley and installed it.the noise was still there,wtf? I spun the new tensioner before I put belt on and heard a slight scrub noise,what would cause a new tensioner to make noise after installation? Thanks.
    Posted via Mobile Device
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    If the tensioner caused a vibration on the belt, that accelerates the wear on it, so you could have wore the belt down and it could need replacing.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    Well,I had more time this morning to work with it and found the tensioner pulley was rubbing the tensioner slightly,so I sanded some material off the plastic pulley to gain clearance and it was a little better but the noise was still there so I removed the a/c belt and the noise was gone.this coming weekend i am going to replace through a/c idler and tensioner pulleys and see what happens.I hope it is not the compressor.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Sometimes the AC compressor clutch will gently rub against the compressor pulley. Check that out also.
    If thats the case, the clutch can be adjusted for a little more clearance.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    ok,thanks. going to check it out this coming sunday and remove the secondary air and since the tcs off and abs inop light came on,i will have to investigate that too.hooked my code scanner up and no codes other than p1133 and p1153 that seem to be permanant,lol
    Member transamgirl89's Avatar
    Dec 2009
    Dacula, Georgia, United States
    2001 RS Camaro
    Is it a high pitched squeal? I had that and it turned out to be the idler pulley.
    Senior Member kenro23's Avatar
    Feb 2011
    Houston
    '00 SS
    i am going thru that same situation. i have replaced both pulleys, the belt and even replaced the a/c bracket. after i replaced the bracket, the noise stopped for about a week. now it's back, but only until the car gets warm and then the noise stops. my mechanic seems to think that now the pulley needs to be re-aligned. maybe you should check your bracket also, as it may be bent.
    any suggestions to my situation? if it is my compressor, i am just gonna remove the a/c all together and be done with that shit
    Orlando, FL
    Mean Black
    Quote Originally Posted by kenro23 View Post
    Does the noise happens with the A/C off? Are you sure the noise is coming from the A/C pulleys? Did you replace the idler pulley and idler tensioner?
    Junior Member HodgeWS6's Avatar
    northwest ohio
    98 TA WS6
    just my 02cents, but my 98 was doing this, and it was my crankshaft pulley. there was rust pits in the grooves the belt ride in causing it to lose traction on the pulley until the belts warmed up. hope that might help
    C5 Vette
    Apr 2011
    Virginia
    Electron Blue
    2003 Corvette Coupe
    I had the same problem. I replaced everything belt related plus the belt two times. Turns out the idler bracket had somehow gotten bent thus causing the belt to not align properly. I put up with the squeeling for two monthes will trying to track down the problem.
    98 T/A w/ mods, 00 FBVert
    Cutlass how do you adjust this?
    DFW
    '18 CTS-V
    '13 ZL1
    im in the same boat. sounds more metallic than a belt issue at startup until it warms up. shreaks like shit! takes the fun right out of driving the car.
    when i remove the A/C belt, no noise, nothing at start up or driving. i checked all the tensioners/pullies and they are good and spin freely. not that i need A/C but it would be nice. perhaps ill take the A/C belt off again and put it on only if i have to.
    Orlando, FL
    Mean Black
    the pulleys can spin freely but that doesn't mean the bearings are bad. try to get a hose or stethoscope and listen to the pulleys when you free spin them. They shouldn't make any abnormal noise.
    DFW
    '18 CTS-V
    '13 ZL1
    I guess I should have included I did that as well, while I was checking everything under the car...fml...
    rsg98Z28 rsg98Z28's Avatar
    Atlanta, GA
    1998 Camaro Z28 vert
    It could just be cheap replacement parts, ive heard brand new belts squeel like hell, try going to napa and getting their higher end belts.
    Madison, WI
    2001 Silverado Z71
    There are AC clutch tool kits out there that are used for replacing the compressor clutch and/or pulley. I use the clutch removal tool to pull the clutch away from the pulley a little bit
    something like this
    Feb 2011
    Houston
    '00 SS
    yes the noise happens with the a/c off. no i am not sure at all. i do know i have replaced everything that has to do with the a/c except the compressor. i have been thinking that it's the crankshaft pulley. my mechanic thinks it isn't that. also, i have done all the stethoscope stuff as well and nothing.
    Feb 2011
    Houston
    '00 SS
    this is what i have been telling my mechanic and he doesn't think that is the case. i have no more options than to check that out. i think he is just lazy and doesn't wanna check it. shitty think about living in hawaii. honestly wish i knew someone that could just help me do it cause i don't know how on my own. well, not everything i should say
    Quote Originally Posted by HodgeWS6 View Post
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    ive got an undetermined queak as well, and the ac doesnt have the belt on it so i know its not that...ive changed the belt and tensioner...perhaps the idler pulley..
    Feb 2011
    Houston
    '00 SS
    so if my noise doesnt get fixed and it is my crankshaft pulley should i get a ud pulley? is there any other types of pulleys that i will need in other places? is it really worth the money to even get one?
  1. Can't get crank pulley off? tried using pulley puller
    By JehalinTA in forum Internal Engine
    Last Post: 06-22-2011, 06:06 PM
  2. MMS Crank Pulley, Reichard Racing Pulley
    By Hodgesz28 in forum Parts For Sale / Trade
    Last Post: 08-18-2006, 08:38 AM
  3. Replies: 1
    Last Post: 01-18-2006, 12:11 PM
  4. Max out that 6 rib ATI Procharger Pulley Setup.. 2.5" 6rib Pulley for Sale
    By HUGGER ORANGE SS in forum Parts For Sale / Trade
    Last Post: 01-16-2006, 06:37 PM
  5. Squealing noise after underdrive pulley install...
    By bbfirebird in forum External Engine
    Last Post: 12-18-2005, 01:28 PM
