Thread: Opinion on these LS6 Intakes
08-27-2010, 07:17 AM #1
I'm looking at these 2 intakes, asking for opinions? Both are in my price range
*Sorry for the sizing and quality of pics, this is what was emailed to me*
This one he is asking for $325 for just the intake, it's new, hasn't been installed. If I want I can get the anodized fuel rails and 30lb injectors for an additional $275
This one is asking for $375 with 42lb injectors. (why so high don't know, he's not running turbos, maybe N2O?!?)
I also have 3 more questions:
1) With bigger injectors would I need a better fuel pump? (I'm not planning on going to turbos or super charger for a long while if ever. So If I did get the 42lb injectors I'd probably try to sell them.)
2) Can you paint the intake? (It's a composite plastic right?) If so what type of paint would you use? (I would want to try to match the NBM color)
3) What else would I need to install a LS6 intake? New gasket?? anything else...
08-27-2010, 07:52 AM #2
I would go with either one.
The 30 lb injectors are not worth the money imho
The 42s is what I run and yes they are a little big but with a tune they are fine. Plus if I do upgrade even further I will be fine.
About the painting yes its plastic paint away. I did my ls6 intake with spray paint from home depot that was very close to nbm.
What other mods do you have? If you are not over 400 hp you have nothing to worry about with the fuel pump
I think I covered everything.
08-27-2010, 07:58 AM #3
I think it depends on your budget.....If you don't plan on major mods then you don't need bigger injectors. Use the money for parts you need now. I have a 6.0 motor, stock 317 heads, kooks LTs, a torquer 2 cam and all bolt-ons...I still have stock injectors.
08-27-2010, 08:41 AM #4
My sig has my current mods. In regards to future engine plans I want to go with a LS6 crate, not sure on heads and a cam. But those are well into next yr maybe 18 more months away.
00 FB Vert - Stock
Have a few ?'s about air intakes.
By lances in forum External EngineReplies: 4Last Post: 05-13-2013, 01:18 PM -
How many different intakes?
By Ramairgod84 in forum External EngineReplies: 12Last Post: 01-01-2010, 01:56 PM -
intakes
By crazy dave ls1 in forum External EngineReplies: 10Last Post: 12-05-2008, 12:20 PM -
Do LS1 intakes have no EGR???
By tnmotown in forum External EngineReplies: 9Last Post: 01-13-2008, 08:49 AM -
Did any LS1 intakes come w/ egr?
By socmninja in forum External EngineReplies: 16Last Post: 07-24-2007, 07:27 PM
