Thread: No start fuel pump problem
07-05-2017, 11:52 AM #1
- Jul 2017
- Brandon,ms
Hey guys I'm new to this site and here because I have ran into a problem I can't figure out.
1998 z28 Camaro
Ls1
I just put a new motor in my car and everything was going great until one day I went to crank my car and it wouldn't start and my gauges started going crazy and a day or two passed and now my fuel pump will not prime but my car turns over and I cannot read my ecu.
I have checked:
Fuel relay
All fuses
Replaced fuel pump
Replaced battery
Checked harness for broke or bad wires
Power going to the pump
Security light goes off after a few seconds
No check engine light
Any help would be greatly appreciated!! Thank you!
07-05-2017, 05:39 PM #2
So you have power at the actual pump, but the pump doesn't kick on when you turn the key?
Sent from my SM-G955U using TapatalkBoost gets you laid, unless your name is Jon.
07-07-2017, 08:03 PM #3
check the grounds?
ECM harness tighten?
07-08-2017, 02:01 AM #4
Did everything swap over utilizing the '98 harness, or did you retrofit a newer engine and harness into your car? The '98 has a "one year only" PCM and there are apparently some differences. Like Scott mentioned, a disconnected or faulty ground can wreak havoc with electrical components. How about the ground on the back of the driver side head?
Still wont start after fuel pump install
By OneFastZ in forum General HelpReplies: 54Last Post: 08-10-2015, 07:31 AM -
Ls1 won't start/ just replaced fuel pump
By Bigjames25 in forum General HelpReplies: 7Last Post: 10-09-2013, 09:02 PM -
Help: changed fuel pump still wont start
By izzhemp in forum General HelpReplies: 10Last Post: 12-30-2011, 04:49 PM -
New fuel pump, drove it, then wouldn't start
By GottaHaveLS1 in forum General HelpReplies: 10Last Post: 07-02-2008, 07:43 PM -
Fuel Pump Pump Problem?????? Help!
By undertakersT/A in forum General HelpReplies: 4Last Post: 04-24-2006, 09:55 AM
