Results 1 to 2 of 2
Thread: Injector and MAF HELP PLEASE!
11-24-2007, 01:50 PM #1
- Oct 2006
- Central Ohio
Black- 1985 Iroc-Z
I have an 80's TPI system on my Iroc, and I was curious whether LS1 injectors will work with on the TPI or are they different? Also, whether there is a difference between the MAF sensors from the 305 and 350 engines in the Camaro's, and is there a difference from the Corvette from the Camaro's? Can I use the Corvette one on my car? Please help me, I need to know whether these injectors are the same and whether or not I should buy a MAF sensor. Thanks a lot.
11-24-2007, 03:54 PM #2
- Retired Outlaw Sum Bitch
Well I dont think you can modify the clips actually to fit the LS1 injectors.....two different animals.....this is based on the assumption your running the TPI fuel rails.....the Corvette MAF is calibrated at a higher flow rate.....this will screw up your ECM....unless you tune for it....
injector??
By Racer X Vpr Klr in forum Forced InductionReplies: 6Last Post: 01-09-2010, 08:26 PM -
Injector ?
By Bottlefedz28 in forum External EngineReplies: 2Last Post: 12-06-2009, 05:12 PM -
New injector help!
By XcamaroZ06X in forum General HelpReplies: 2Last Post: 09-10-2009, 12:16 AM -
Injector Help
By ProchargedSSGun in forum External EngineReplies: 0Last Post: 04-21-2008, 03:52 PM -
injector ?
By sgt0704 in forum General HelpReplies: 1Last Post: 08-09-2007, 05:13 AM
