Results 1 to 20 of 23
Thread: I need help bad!!!
03-14-2008, 06:31 PM #1
- Mar 2006
- Scotrun, PA
Pewter- 2002 Z28 (sold)
I need help bad!!!
Tonight I decided to change out my spark plugs. First time I am ever doing this on the car.
I do the drivers side, no problem. Considering I hae no idea what I am doing, I was impressed to do this side in 45 min.
Onto the passanger side. I got the first two out and in within about 20mintes.
My problem is, #6 spark plug boot wont come loose. I have since split the wire in two. How can I now get this boot off? I barerly have any leverage to get in there with my hand to rip it out.
Any ideas, greatly appreciated.
03-14-2008, 06:48 PM #2
What all did you remove on the passenger side? I took the AIR and coilpacks out and had enough room for some maneuvering.
I had something similar happen to me and I had to fight it a bit. Try to twist it from the boot while pulling. It'll eventually pop. Cussing and yelling gives you an extra hormone boost.
03-14-2008, 06:56 PM #3
- Mar 2006
- Scotrun, PA
Don't know what it is called, but the tube to the manifold. That was about it. It was considering the Coil packs, but as my luck would have it, I would break something there as well.
There is about 2 1/2 inches of space for me to shove my hand in. I can barley get my hand around the boot. If I knew how, I would break that bitch off.
03-14-2008, 07:24 PM #4
- Mar 2006
- Scotrun, PA
Well, i don't know what I did, but it popped right off. I had the spark plug boot removed and plug changed under five minutes. So I now have 7 out of 8 done.
Any tips on how to get the boot off of #8? I just tried and I was not able to get a grip on it.
03-14-2008, 07:24 PM #5
03-14-2008, 07:31 PM #6
- Mar 2006
- Scotrun, PA
03-14-2008, 07:56 PM #7
coil packs are easy to remove, all coils are mounted on a single bracket, unplug main electrical harness to coil packs and then remove bolts that hold bracket to vavlve cover. 6 0r 8 bolts , i think they are 10mm. The last bolt in the back is only hard one, blind bolt you have to feel it. I leave the last bolt out for future plug changes which i do a lot cause of spray. As far as the boot you have to twist it around back and forth to break seal. Then it comes off easy
03-14-2008, 08:02 PM #8
03-14-2008, 08:03 PM #9
You can go to an Auto Parts store and get a tool that is made just to remove spark plug boots. Im not sure what its called but when you get to the store tell them what you need. They are like a pair of pliers that curve a 90 degree angle at the bottom. They are used to pull plug wires off plugs in tight places.
03-14-2008, 08:07 PM #10
- Mar 2006
- Scotrun, PA
So when I take the coil pack bolts out, Does the coil pack come out of the car completle or do I set it aside like I did with the EGR tube?
03-14-2008, 08:13 PM #11
I think the 02 is the same as 00, # 8 is very easy to get to from under car , on 00 I had no need to remove coil pack or remove any thing to change plugs, I will state that first time I change plugs I had to get my son to remove wires , as I was not strong enough, look at the angle the plugs are pointing , point differant way on each side , use some never sease on threads, and dilect grease on wires
Y2K SS (SLP #239)
Completly STOCK heads/bore/stroke/weight
& NOTHING else ---is stock
"NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
ps: I am not soliticing work as I am retired
>>>info on alignments
http://www.jgruggles.com
03-15-2008, 05:45 AM #12
I have a 2000 and did not have to remove anything, I also got #8 from under the car and it was the easyest to get out. Good luck to ya.
03-15-2008, 07:15 AM #13
03-16-2008, 06:38 PM #14
- Mar 2006
- Scotrun, PA
well, my neighbor and I were talking and he took a crack at it. He had it replaced with in 15 minutes. Guess it pays to have a mechanic as a neighbor.
Now I just have to check all the wires as there is a ticking sound now.
03-16-2008, 06:43 PM #15
- Oct 2005
- Centereach, NY
Arctic White- 1998 Formula
you guys are lucky........on my 98 the coils come off seperately........the valve covers suck too........
03-16-2008, 06:49 PM #16
- Mar 2006
- Scotrun, PA
BTW - Coils were left alone. He stuck his skinny hand in there. Only thing removed was the EGR tube.
03-16-2008, 06:58 PM #17
- Oct 2005
- Centereach, NY
did my #8 from underneath...took 5 min......
did it w/ headers on though, never did it with the manifolds on it......
03-16-2008, 07:08 PM #18
I did all 8 plugs on my '98 without removing anything.
Very tedious and time consuming, got #8 mostly from the bottom.
03-20-2008, 03:06 AM #19
- Mar 2006
- Scotrun, PA
my tick is gone. It was the EGR tube. Went to GM and got a new one for 8.63. they were the only place in town that was able to get it in under a week.
So I go home, and proceed to replace the gasket and it FALLS under the engine on the K-Member. So now I like SHIT! I just wasted 9 bucks cause I did not think I was ale to find it.
I stick my hand down in the engine compartment, and I pull out the OLD one. When I took it off, I did not see that it had fallen below the engine, I thought it was stuck to the EGR tube. Long story short, My tick is gone. So is the new gasket cause I can't find it.
03-20-2008, 02:05 PM #20
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
