Thread: Hign engine idle
04-14-2010, 04:21 PM #1
- Jun 2009
- Houston
Blue- 2001
Hign engine idle
Hi guys and gals. I am new to the LS1 world ,so please help me the best you can. I have 01 Formula ram air. After my car is warmed up and runs for a while, it starts to idle higher and when I have it gear I can let off the accelerator and the car will keep going at the same idle. Please point me in the right direction.
04-14-2010, 04:34 PM #2
How high is the idle going? How many miles? Any mods? You can pull the IAC motor and clean it, they build up with grime and carbon and sometimes stick. I would also clean your MAF and Throttle body while its open..
04-14-2010, 06:47 PM #3
- Apr 2008
- Madison, WI
check your PCV hose. They like to deteriorate in this area and PCV housing right next to it. It'll cause a vacuum leak and high idle
04-14-2010, 07:04 PM #4
I am having the same prob. My 01 has 195,000 miles on it and this is the only problem i have ever had on this car. I have cleaned both TB and MAF. I have replaced the IAC and the other one under it(forgot the name ) I had my o2's checked out and was told they were running fine. I've checked for vacuum leaks and nothing. I replace my pcv every other oil change. This is starting to really drive me nuts. I love driving this car, but this is not helping. I don't know what else to look at.
04-17-2010, 11:30 PM #5
04-18-2010, 06:38 PM #6
The manifold has never been messed with. I had the 02's checked out on the shops laptop. It said hp tuner. I was told they were good. what do you mean spray around the manifold?
04-18-2010, 07:08 PM #7
o2's aren't associated w/ vacuum leaks. If there is a leak in the manifold it will cause a higher idle, if you spray ether around suspected points of interest and there is in fact a leaking gasket you will hear the motor idle go up. Out of curiosity you ever replace your fuel filter? Don't think it would cure it but...
04-19-2010, 06:39 AM #8
I change my fuel filter and pcv every other oil change. I have not heard any sucking sound coming from the motor. I will check the manifold for any leaks. Thank You.
Engine stuttering at Idle
By mike171562 in forum General HelpReplies: 25Last Post: 04-01-2010, 12:03 PM -
Help: Engine idle surge
By Adam_94_T/A in forum General HelpReplies: 0Last Post: 03-28-2010, 03:24 AM -
Engine Won't Idle
By kempfer99ta in forum Classic MuscleReplies: 3Last Post: 01-24-2010, 04:57 AM -
Engine races At Idle
By midnitejam in forum General HelpReplies: 6Last Post: 05-13-2009, 01:36 PM -
engine idle trouble help!
By larryndog in forum General HelpReplies: 6Last Post: 07-20-2006, 12:32 PM
