Results 1 to 2 of 2
07-23-2008, 10:31 AM #1
Fuel Problem and Throttle Position Sensor??
I'm still trying to find out how I can solve my fuel problem... and no i still haven't checked my fuel pressure (i will tomorrow). a friend of mine mentioned that you can toy with a throttle position sensor to get more fuel at WOT. i'm not sure if this is true for fuel injected cars and i don't even know where it is on my 99 T/A. does anyone know anything about this.
Just to let you know, i've replaced my fuel filter and fuel pump (the sock on it was filthy) and still haven't solved my problem. my tuner showed me on his laptop where i was leaning out at WOT. AF ratio was around 12.8:1 or something like that. any advice is appreciated.
07-23-2008, 02:42 PM #2
throttle postion
The tps itself cannt add fuel but the tps tells the computer exaclty where the throttle blade is so that it can be determined whether your are attempting to idle, cruise at a steady state or accelerate or declerate.
But it is important to know exactly what the threshold is between closed throttle and part throttle for calibration to ensue that the computer actually uses the idle tables.
Question: Need to change Throttle Position Sensor
By LS1BL in forum General HelpReplies: 13Last Post: 02-20-2013, 12:02 PM -
Question: Bad throttle position sensor?
By clg82 in forum Firebird / WS6Replies: 7Last Post: 07-29-2010, 12:10 PM -
Help: Installing a throttle position sensor
By 454transam in forum External EngineReplies: 4Last Post: 06-02-2010, 11:43 PM -
Throttle Position Sensor Voltage
By SilverFish in forum General HelpReplies: 1Last Post: 08-30-2008, 12:33 PM -
By dpinson in forum NitrousReplies: 6Last Post: 09-24-2007, 01:22 AM
