Thread: DRL delete
07-01-2009, 04:15 AM #1
DRL delete
Okay, I located the DRL module behind the stereo and disconnected the small plug.
There are two and the large one does not disconnect, at least to my knowledge.
After disconnecting the small plug, the DRLs do not come on and both blinkers work as advertised. So far, so good.
When I put the headlights on, only the left DRL comes on.
Did I miss something or do I have another issue?
Thanks,
07-01-2009, 06:07 AM #2
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Read this
http://xse.com/leres/ss/drl.html
07-01-2009, 06:20 AM #3
- Apr 2008
- Madison, WI
maybe some info here will also help you.
http://www.ls1.com/forums/showthread...ht=drl+disable
07-01-2009, 01:17 PM #4
Still not clear but, I'll try the A, C wire bridge to see if that does anything. Only comes on with the headlights on which doesn't make any sense but, I'll try.
Thanks guys,
GUNS
07-01-2009, 03:34 PM #5
- Nov 2008
- harrisburg pa.
black- 02 vette vert
dont change anything yet! if you unplugged the smaller plug to the right side you dont have drl's anymore. your bulb has 2 filiments, one for parking lights and a brighter one for turnsignals [also formerly for drls] if both turnsignals work properly there is no problem. when you turn your headlights on your parking lights are on also. you probably have a burnt out parking light. turn on your p-lights only and see if one side is not working, should be the same as when you turn your headlights on. turnsignals working + light out with headlights on = replace bulb.
07-01-2009, 03:43 PM #6
is there a similar process of turning off drls on a w-body?i would really like to turn off my drls on my 05 monte carlo.thanks
07-03-2009, 04:40 AM #7
Question: MAF Delete??????
By 98SSLS1OWNER in forum Computer & TuningReplies: 37Last Post: 12-06-2010, 03:03 PM -
MAF delete?
By tomz28 in forum General HelpReplies: 20Last Post: 06-30-2009, 02:36 PM -
EGR & AIR delete
By 96t/a in forum LT1Replies: 10Last Post: 04-10-2008, 04:33 PM -
Delete This
By ss~zoso~ss in forum Political / Debate ForumReplies: 0Last Post: 02-06-2008, 12:53 PM
