Results 1 to 2 of 2
09-13-2018, 04:43 AM #1
- Sep 2017
- Villabé (France)
Pewter- 2000 Z28 Camaro
Can I install a 93-97 v6 Fuel tank in a 98 T/A
Hi,
It's time to replace the old rusted fuel tank of my 98 T/A. Due to the rust, there are small gas leaks under the fuel tank...
I've read that the 98 fuel tank is made of steel, like the 93-97 ones...
I plan to buy an used one. But here in France, the 93-97 T/A are very hard to find. There are lots of v6 Firebird.
My question is, can I install a fuel tank of a 93-97 v6 Firebird in my 98 T/A. Can you tell me if a 93-97 v6 fuel tank is the same than mine...
Thanks a lot.
09-13-2018, 06:41 AM #2
The tanks have different part numbers but all fuel tanks are the same for each model of Firebird. Meaning the V6's have the same tank as the V8's for both >97 and 98. So if you can find a 98 V6 you can use it.
99's and up also have a different part number as well. So if you get one of them you'll need to change the pump and sending unit as well. IIRC it really is the sending unit that needs to be changed, I believe the actual pumps are the same but I would check further into that to make sure.
The >97's will fit and all but the issue will be the fuel pump and sending unit. I believe they are very different in mounting because the LT1 fuel pump vs the LS1 fuel pump are different.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Belstein Shocks, Hotchkis Springs (1" Drop), YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.73 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
00 FB Vert - Stock
'00 SS Fuel Tank Question
By blue_rose2001 in forum General HelpReplies: 7Last Post: 07-28-2015, 11:48 PM -
Help: 98 TA fuel smell coming out of the fuel tank neck/cap
By JayTA98 in forum General HelpReplies: 23Last Post: 04-09-2014, 09:35 AM -
fuel tank
By pocket rocket in forum GTOReplies: 7Last Post: 11-09-2009, 04:33 AM -
F/S: 255 LPH in tank fuel pump
By nevrlift in forum Western MembersReplies: 0Last Post: 09-11-2007, 02:22 PM -
Fuel Tank Size
By whiteflash in forum Firebird / WS6Replies: 70Last Post: 04-02-2007, 10:38 AM
