Thread: 1999 trans am smog pump?
03-22-2010, 09:44 AM #1
The Service engine soon light came on earlier today, i toke it to get read and this is what i got.
P1416
Air system bank 2 fault
Explanation
During the air system test the ECm looks for a change in the O2 sensor voltage- No change was detected
Probable cause
-Air pump electrical circuit fault
-Blocked air system
-Failed air pump
And I was told it could be the smog pump.
No real idea what it is, It isnt running any differently and still getting average milage...i really dont know what im supposed to be at just depends how i feel u know XD.
any ideas?
03-22-2010, 09:51 AM #2
If your has failed I'll sell you mine, I've deleted both air and egr from my T/A...
PM me if interested...
03-22-2010, 10:48 AM #3
Ill let u know, Im not sure what it is yet
03-24-2010, 09:46 AM #4
uhh the light went away, but this is the second time its happened? what you think would cause it? last time was 3 weeks ago
03-24-2010, 01:14 PM #5
Have you pulled out and check your O2's yet?
Pm Frost he might have some suggestions for you
03-24-2010, 05:48 PM #6
- Apr 2008
- Madison, WI
does this sticky help you?
03-26-2010, 12:46 PM #7
yes it does, very helpful if it doesnt rain ima try to do this
03-29-2010, 07:27 PM #8
- Apr 2009
- Michigan
Pewter- 2001 Pontiac Trans Am
Your air check valves might be clogged. I had the same problem replace both of them myself. Only cost $24 for two of them. The problem went away
03-31-2010, 03:58 PM #9
- Dec 2007
- Temple, Tx
red- 2001 Ws6 Trans Am M6
is it still the stock air intake? i installed the k and n kit on my ta and the smog pump had a second little filter of its own. about a day or two later i started pulling similar codes. come to find out when i installed the mini filter for the smog pump, i made a kink in the hose to it. five minutes with some rubber hose cutters and problem solved.
smog pump
By Black beauty in forum LT1Replies: 8Last Post: 05-28-2014, 10:43 AM -
Smog Pump location?
By Patsy57 in forum External EngineReplies: 5Last Post: 06-27-2009, 02:37 AM -
looking for a 00+ Smog pump
By FORMULA7 in forum Cowhands, Local Parts and Fish BaitReplies: 2Last Post: 09-22-2006, 10:48 PM -
Two Regular Problems, Help! trans mount & smog line
By Roxboro Burnout in forum General HelpReplies: 3Last Post: 04-10-2006, 12:55 PM -
What items can be taken off (ex. smog pump)
By notchback in forum External EngineReplies: 2Last Post: 11-30-2005, 05:28 PM
