Results 1 to 17 of 17
    Milwaukee
    1993 Pontiac Trans Am
    Lt1 Ignition Problem.
    I have a problem. I have a 1993 Trans am Lt1. When my car is cold it runs smooth no miss firing, no hesitation but once the engine warms up the car starts hesitating when i try to accelerate, a couple times at a stop light when it turns green and accelerate it shots off but starts up soon after. Remember it only happens when the engine gets hot, no check engine light is turned on... I changed my spark plugs and cabels, and all the vaccum hoses are new.... If any one knows what the problem is ill be greatly thankfull for the help...
    Aug 2006
    Missouri
    94 Camaro Z28
    Everyone's thinkin it, I'm just sayin it...optispark.
    Milwaukee
    And you are right. In my case it was rotor.. Thanks.
    Rockford, IL
    whats the best replacement for the optispark and how much does it cost? im just wonderin cuz im in the market for a mid-high mileage lt1 fbody and would like to know about its most common problem
    Milwaukee
    I guess i was wrong i changed the distributor with an MSD upgrade but the problem got even worse..... Any one have anyother suggestions?
    Member FUELS94's Avatar
    Cheney Wa.
    I see in your other post you just changed the cap and rotor, but not the opti sensor as well. Your going have to take it a part again. But before you do that change the TBS sensor to see if that helps your hesitation problem. If that doesn't work back to opti sensor itself.
    Vinny
    1996 Z28 LT-1 (with basic bolt-on)
    East Texas
    my dad has a 93 Lt1 and we have replaced ours like 3 times already and about to replace it one more time. Unfortunatly he has already bought another one from Oriellys, but I found this unit on the internet while looking around. Heres the site you might want to check out. Dont know much about them but its worth a look.
    http://www.dynaspark.net/products/
    Aug 2006
    Missouri
    94 Camaro Z28
    Whenever my opti goes out, I AM NOT going with another opti-style unit. I plan on getting the Delteq replacement. Its kinda like the LTCC kit, but its a complete plug-and-play unit, no fabrication at all.
    Rockford, IL
    Quote Originally Posted by BlackLT1Z28 View Post
    how much does that cost?
    Milwaukee
    Car will be going to dillership for scan tomorow..Let you now whats up...
    Aug 2006
    Missouri
    94 Camaro Z28
    Quote Originally Posted by ATCharming View Post
    Last I saw, I think it was about $600 or so.
    Milford, CT
    93 Trans Am
    Having the same problems. Been misdiagnosed for a while, but it seems like the opticrap has finally caught up to me.
    My T/A is on the shelf until I can scrape up the pesos for the Delteq kit.
    I'm at 80K on my 97 LT1, no opti issues yet...........
    Aug 2006
    Missouri
    94 Camaro Z28
    Quote Originally Posted by my5thNewUsernameHere View Post
    Don't jinx yourself.
    Milwaukee
    It was distributor..
    2nd last of the lt1s EVAR 94z28l's Avatar
    colorado
    purple pearl metalic
    1994 Z28 Camaro
    no joke, i did it
    Mustangs in the mirrors 02Hawk's Avatar
    New Jersey
    2002 Firehawk Trans Am
    Quote Originally Posted by 1993RedLt1 View Post
    lemme guess you had 1. a bad water pump not too long ago, or two just changed to the msd... When the water pump goes like my 93 TA did it leaks right down into the optispark distributor and bam you have one big mess. I tried to replace it with the MSD and it was crap unfortuntely.
    Replace it with a stock or just do the coil pack conversion
  1. Ignition problem on 02 Transam, Please help!
    By jayfire in forum General Help
    Last Post: 10-23-2013, 07:09 AM
  2. Ignition Lock problem
    By slims00ls1z28 in forum GTO
    Last Post: 07-24-2009, 08:37 AM
  3. ignition problem
    By mctcash in forum General Help
    Last Post: 06-11-2008, 06:31 PM
  4. Ignition Problem/ Concern ??? Help
    By 01JameSS in forum General Help
    Last Post: 01-10-2006, 10:17 AM
