10-04-2011, 01:49 PM #1
- Apr 2009
- tn
Intake air control valve question
Does anyone know of a way of checking the iac valve without a scanner? iac sensor is good. with it removed I know your not supposed to but if you push or pull on it should it move? Car is idling high untill i cover the iac port then its fine. Also if i remove it and reinstall it does that require a reset? And i keep reading about adjusting the lenght how do you do that? And with it out of the tb if i turn on the power should it move?
Thanks in advance.
10-04-2011, 04:32 PM #2
have you ruled out vacuum leaks? That's where I would start first. Check the pcv hoses and any other vacuum hoses.
10-04-2011, 04:55 PM #3
- Apr 2009
- tn
Yes i checked everything and soaked them all in starting fluid so pretty sure there is no leak
10-29-2011, 08:27 AM #4
- Oct 2011
- CT
Black- 1993 Trans Am
what years are we talking here?
10-29-2011, 08:29 AM #5
- Oct 2011
- CT
obd1 if you just unhook its plug and it idles the same than yea its probably shot. I'd check your wires for breaks or chews.
LT1 Intake air controller valve question
By dirttrax in forum General HelpReplies: 1Last Post: 10-04-2011, 09:45 PM -
New valve stem seals the same for exhaust and intake valve?
By JehalinTA in forum Internal EngineReplies: 1Last Post: 07-03-2011, 08:16 AM -
idle air control valve???
By unibuga in forum General HelpReplies: 19Last Post: 09-30-2010, 06:02 PM -
Help: Idle control valve
By mo$z28 in forum General HelpReplies: 19Last Post: 06-12-2008, 08:17 PM -
WTB Air Injection control valve
By RE AND CHERYL in forum Parts Wanted / TradeReplies: 0Last Post: 08-14-2007, 11:14 AM
