Thread: header question
    Member jAgZ28's Avatar
    LINY
    bright red
    1993 z28 camaro
    header question
    i want to get a set of pacesetter headers mids probably, but can i use an off road y pipe and still pass inspection? i figure its called an off road y for a reason and new york does have fairly tough inspection standards. i know i cant use the stock y cause i called the place that was what i was told. so can i modify the off road y to pass inspection or will it pass the emissions test the way it comes?
    my car is a 93 z28 a4 hooker catback, qtp cutout, k&n cai, vortec elbow, high flow cat, tb bypass, tb airfoil, rk sport ss hood
    LTX N20LT4's Avatar
    Cali
    10's N/A
    Gotta have a catalytic converter to pass inspection. Once you pass, pull the cat off and run off-road.
    Aug 2006
    Missouri
    94 Camaro Z28
    No cat = no pass
    LINY
    bright red
    1993 z28 camaro
    the off road y eliminates the cat?
    LTX N20LT4's Avatar
    Cali
    10's N/A
    yes.
    LINY
    bright red
    1993 z28 camaro
    can you incorporate the two by cutting the y enough to fit the cat or is there not enough pipe for that to work? theres got to be some way to make it work. or maybe i should go with shorties like bbk or edlebrock
    LTX N20LT4's Avatar
    Cali
    10's N/A
    Quote Originally Posted by jAgZ28 View Post
    Whatever you do don't go with either BBK's or Edelbrocks. You won't notice a difference in performance - that statement coming from experience. Shorties suck. Go with a set Mid-length headers like Pacesetters, which flow better than the above mentioned and still allow the cat to retain the factory position, hence allowing you to pass smog.
    Feb 2007
    Atlanta
    94 z28
    the pace setter mids come with a new y and u dont have to move the cat and it will still pass i had them on my 94 i just put the long tubes on there today fixing to start on the exsaust i hope i can get it to pass lol
    Aug 2006
    Missouri
    94 Camaro Z28
    I have the pacesetter LT's and ORY, but I had my exhaust shop put the cat back on the ORY so I can pass visual inspection. And I know its no longer considered an ORY.
  1. once again a header question
    By bmwmteam in forum External Engine
    Last Post: 05-04-2009, 06:46 PM
  2. Header question
    By LETHALxLS1 in forum External Engine
    Last Post: 01-24-2008, 05:33 AM
  3. Header Question
    By garver in forum External Engine
    Last Post: 11-11-2007, 05:25 PM
  4. Header Question
    By fastfirebird2002 in forum External Engine
    Last Post: 05-21-2007, 03:12 PM
  5. Header Question
    By TransAm45 in forum LT1
    Last Post: 01-04-2006, 05:18 AM
