Electronic-Speedometer Converter - Abbott Cable X
An easy way to get your speedometer cable to work with an electronic speedo transmissionModifying an older Pontiac is often like painting a house. The large surface areas go very quickly, and then you get mired in the trim and wood work. When swapping or upgrading components, they often bolt into the Pontiac quite easily; then you end up spending weeks trying to connect something as simple as the power-steering bracket. Anyone who has worked on cars knows it's only a matter of when the modification will hit a brick wall, not if it will.
Photo Gallery: Electronic-Speedometer Converter - Hook Up A Cable-Driven Speedo To A Modern Trans - High Performance Pontiac Magazine
More...
