    Member SpeedWorld's Avatar
    Minnesota
    What other mods would help?
    My mods are below and I was wondering what else would be a good idea to do. Looking mainly for power mods. Looking to maybe bump over the 400rwhp mark. I am looking at things outside of a supercharger, turbo, and nitrous. What else would be a good bargain and be pretty effective? Thanks for any input!
    2001 Chevrolet Camaro SS
    Thunder Racing 224/224 563/563 on 112 LSA
    FLP longtube headers and y pipe
    GMMG catback
    Underdrive pulley
    LS1 motorsports lid
    PRO 5.0 with Lous Short stick
    Lower control arms,adjustable panhard bar, subframe connectors.
    387hp/379tq
    DFW
    '18 CTS-V
    '13 ZL1
    Heads and then take off the crappy Ls6 intake and get a real man's intake: a FAST 90/90 and you will be close to my current setup and power. only thing is, my 224 cam has a .581 lift...
    2013 ZL1: °°590rwhp/576rwtq°°
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Just cam it, you will be well over 400...
    DFW
    '18 CTS-V
    '13 ZL1
    Quote Originally Posted by JwMonE99 View Post
    he already has a cam...
    Minnesota
    Yeah, what he said. It's not that big of a cam, though.
    DFW
    '18 CTS-V
    '13 ZL1
    that's ok im running a 224/224 .581/.581 @112 lsa and putting down 444rwhp...
    224 cams are stronger than you think...
    Minnesota
    How much for the heads and intake? Where would you recommend buying the heads and which ones?
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Ooops I missed that part, I was thinking of tires lol.
    So wouldnt a nice set of heads and intake take care of it?
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    trick flows' w/ FAST 90/90
    DFW
    '18 CTS-V
    '13 ZL1
    im running Patriot Performance Ls6 "style" stage II heads (old 6.0L castings): 2.02" int/1.57" ext, 59cc, and a ported FAST 90/90...
    trick flows have had some issues for some users with their coolant holes in the heads not lining up with the holes in the block. do some research and find out which heads (Dart, Trick-Flow, PRC, AFR, Patriot, etc) fit the goal you have set for your car. dont just slap heads and an intake on your car and call her done. for the money spent for heads and an intake, make sure you get your money's worth...
    Omaha, NE
    2000 Z28 Camaro
    With what supporting mods though?
    Fast 90
    Ported TB
    Bigger Cam
    Maybe true duals
    DFW
    '18 CTS-V
    '13 ZL1
    Quote Originally Posted by allbaugh_04 View Post
    Fast 90
    Ported TB
    Bigger Cam
    Maybe true duals
    Mods are:
    SLP Lid
    SLP Bellow
    FAST 90/90
    Patriot Heads
    Comp Cam 224
    Ls2 Timing chain
    Ls6 Oil Pump
    LT's
    **just installed TD's this past weekend (not retuned yet), the 444rwhp was through ORY/SLP LM catback
    HP Tune
    basically he has everything I do minus heads/intake...
    i swapped my Ls1 intake for an Ls6 intake when the heads were installed in Jan. those numbers were 409/386. then in August I swapped out the Ls6 for a FAST 90/90 and w/retune, i went to 444rwhp, my current numbers. soon i will get the car retuned for the TD's and see what if anything i might have gained...
  1. 15 Cheap Mods - 15 No-Buck And Low-Buck Mods
    Last Post: 03-05-2012, 04:20 PM
  2. 2004 Cobra w/mods Vs. R34 Skyline w/mods
    By Packy in forum Kill Stories
    Last Post: 08-31-2009, 06:26 PM
  3. Question: Mods
    By repeter in forum GTO
    Last Post: 02-15-2009, 01:00 PM
  4. Question: doing mods
    By cramn4903 in forum Camaro / SS
    Last Post: 02-09-2009, 05:18 PM
  5. $2000 on suspension mods or on motor mods??
    By greatwhiteZ28 in forum Suspension and Handling
    Last Post: 09-27-2007, 06:04 AM
