Results 1 to 20 of 39
    - STOCK ish - Sarge91's Avatar
    Fairhope, Alabama
    2002 Camaro SS SLP
    What could happen?
    Well its a gas question, now i would rather get real answers to this 1, if i use Mid grade gas, will it f up my ls1? I have had a couple of tanks of it, and there isn't any dings or rattles, i would rather use Premium, but sometimes Mr. Wallet doesn't agree. Thanks
    Member slpcamaro's Avatar
    sunnyvale
    98 ss camaro
    at about $1.30 per tank difference your willing to risk your motor, need I say more?
    Fairhope, Alabama
    2002 Camaro SS SLP
    What am i risking?
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by Sarge91 View Post
    What am i risking?
    nothing..its just better for your engine in the long run..........better performance and gas milage........it is worth the extra $$$ you pay
    Member txz28's Avatar
    sheldon, TEXAS
    dirty aka white
    2000 Z
    i ran reg low grade for 4 yrs and no problems other then lost power but then again i am runnin a bone stock set up
    Arizona
    The computer is pretty good about pulling timing when detonation is present before it even becomes audible,,,,so chances are you wouldn't hear it anyway....unless it's severe.
    Problem is though,,,,with the computer pulling timing it affects mileage to an extent, performance suffers a bit as well.
    If it persists I believe the computer will resort to the lower timing table which in both of my cars is about 6-8 degrees less timing accross the board,,,thats pretty drastic.
    For the slight amount of difference in money I personally prefer high test. I've been running 94 octane in most everything for the better part of 30 years. You get used to the price and adjust accordingly.
    nothing..
    I disagree.
    Knocking (detonation) can ruin a motor quick.
    Spend the money for premium.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    i think it depends on what youre running, if its a stock motor id think youd be fine. Ive heard that under 11 to 1 compression you dont have to worry about detonation.
    My car has never seen premium to my knowledge, but I do get an extra 2-3 mph using midgrade over regular.
    sheldon, TEXAS
    dirty aka white
    2000 Z
    I disagree.
    but Luos your wastin your money in Co you dont get a true occatin split with that gas bc all the corn base thats in it!! another reason why the highest pump gas you can get there is ony 90 or 91 to where as down here in TX I can get all the way up to 97-99 some places and its a true split in the gas
    The LS1 (10.1:1) WILL knock on midgrade at WOT.
    If you run anything under premium with 11:1 it will knock as well.
    Quote Originally Posted by txz28 View Post
    While this might be true....I have personally seen a stock internal LSx ping running our mid-grade. It pulled 10 degrees of timing at WOT from 3400RPM on on a dyno.
    In short....spend the extra $1-2 a tank and put premium in it. Worth it!
    Painted manta stripe
    Omaha, NE
    2000 Z28 Camaro
    if you need to save a 1 or 2 per fill up then cut back on the damn cheez burgers
    sheldon, TEXAS
    dirty aka white
    2000 Z
    Quote Originally Posted by allbaugh_04 View Post
    lol
    Charlotte, NC
    Black 2002 T/A M6
    Green 1997 Ram 4x4
    That's exactly what I did when I bought mine haha..
    Member OneslowZ28's Avatar
    McHenry, IL
    Blue
    Spend the extra $$ OE put it in their manual for a reason.
    2000 SS Black M6
    Around here theres a 15 cent spread in gas grades, today was 3.69 for regular. 3.84 for mid and 3.99 for premium.
    I used to run mid, the difference in gas mileage made up for the price increase. The extra distance i covered over the course of a tank was more than i would have gotten with the extra gas.
    I know when im running regular the motor doesnt sound happy over 4k rpms, but no serious knocking or anything. I think ill use premium next time and try it out.
    You still have the 3.8 car?
    I would think that should run fine on mid-grade. Less compression.
    Here is it....
    $3.85
    $3.95
    $4.05
    Georgia
    2014 Camaro 1LS
    I disagree.
    I have had 4 Camaros and this is the first one I have run only 93 in. The other three Camaros I run 87 and had zero engine problems.
    Were they LS1's?
    Georgia
    2014 Camaro 1LS
    Were they LS1's?
    no, but it was reccomended to run 93
  1. Has anyone had this happen?
    By TA98 in forum General Help
    Last Post: 12-05-2009, 09:46 PM
  2. How does this happen??? Again!
    By FORD RECOVERY EXPERT in forum Almost Anything Goes
    Last Post: 10-31-2009, 09:14 AM
  3. Question: never had this happen before..
    By Brad(WS/Z0.6) in forum Manual Transmission
    Last Post: 10-03-2009, 02:25 PM
  4. Could this actually happen to us?
    By Mr. Hyde in forum Political / Debate Forum
    Last Post: 05-28-2008, 06:49 AM
  5. this ever happen to anyone?
    By badazta in forum Almost Anything Goes
    Last Post: 05-23-2007, 02:20 PM
