Results 21 to 33 of 33
Thread: oil(?) in coolant reservoir
07-06-2009, 11:20 AM #21
I've never had a problem with Dexcool,,,,but I never leave it in there for the 5 year service intervals they recommend either. I change it every year just like any other antifreeze.
The corrosion you speak of happens with the regular antifreeze as well if left in the system too long. I've seen the brown sludge in the older cars as well that use standard antifreeze.
It all boils down to poor maintainance.
07-06-2009, 12:40 PM #22
- May 2009
- pa
I have to disagree...NOTHING EATS LIKE DEXCOOL! I've seen systems TOTALLY destroyed, i'm talking so much damage its hard to believe. I think GM was smart going to it for their dealers sake of filling their pockets with repair money. But it bit them in the butt. Dexcool is without a doubt one of the worst products of all time. I can't think of any other automotive product that has caused so much damage. What suprises me is people who never had trouble with it tempting fate when there are MILLIONS of damage claims out there over it.
07-06-2009, 01:44 PM #23
- Jan 2006
- Shepherd, Michigan
omggggwwaaadddd....its nothing to worry about..my dipstick is/was nasty...its from moisture ..if you realize that its all over the coolant stick..much higher then the coolant level...i bet you do alot of short trips dont you ?? its a nasty brown on the stick from the moisture not being burnt off ..that will happen when you mostly go to op temp
07-06-2009, 01:59 PM #24
I don't think anyone is depriving you of your opinion. I'm just not that convinced, seeing as how I've had 4 vehicles with it,,,,currently have 3 in the stable with it,,,and I just don't have a problem with it in any vehicle.
I also have 7 other cars that use plain old green antifreeze and they too will get the same ole brown goop in them if they aren't serviced regularly. So I don't blame it soley on the brand or type of antifreeze.
In my experience I see it as not being routinely tested and changed no matter what you use.
07-06-2009, 02:15 PM #25
You know what I see in that statement??? Millions of people that don't service their cars. I see it all the time. It's amazing how people treat their automobiles. As long as it runs I just fill it with gas Some people just don't know how, but most just don't care to do it or don't want to spend the money.
Antifreeze ranks right up at the top as one of the most ignored services on a car, right up there with brake fluid. I've seen 10 year old cars that have never had it changed.
When GM came out with a 5 year antifreeze it was a mistake in that it made people think they could ignore it for years. Bad move.
Test any antifreeze with in 12 months of a fresh change and you would be surprised how acidic they become.
Mixing with tap water and/or flushing with tap water does not help matters either.
07-06-2009, 02:28 PM #26
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
My car has lived on DexCool since new.
I change it every spring......system is like new.
07-07-2009, 01:34 AM #27
- May 2009
- pa
07-07-2009, 01:37 AM #28
- May 2009
- pa
07-07-2009, 07:35 AM #29
Dexcool itself doesn't eat anything. Its not corrosive, nor damaging to metal. However, It can sludge up when left in the cooling system too long.
GM isn't the only one to use dexcool. Many other manufacturers use variants of Dexcool that are basically the same forumla, but dyed a different color and with a different name on the bottle.
07-07-2009, 08:26 AM #30
07-08-2009, 05:41 AM #31
- May 2009
- pa
01-10-2017, 11:11 AM #32
- Apr 2016
- Duck Hill, MS
Pewter/Tan- 2001 Camaro Z/28
I know this is an old thread but LAZARETH COME FORTH!! LOL Anyways. I'm dealing with this issue as well. To describe the sludge, it's like algae slick in your hand but brown like mud. Like him it was only in my coolant reservoir. Radiator was completely clean. I took it to a mechanic who is very reputable he said "Blown Head Gasket" previous owner was a Chevy Mechanic. I was hoping he didn't pull a fast one on me. So i did all the tests, checked oil (Fine), Flushed Coolant and lo and behold it's Dex-Cool Orange...i was like well.. Shit. Flushed all that crap out and put some universal in hoping it won't do it again. I flushed the radiator out a few times and took the reservoir out it was super easy 2 bolts and the hose. Flushed it out with water but couldn't get the death cool sludge out. So i put white vinegar in there shook it up really good and a good majority of it came out no problem. So it still had me worried about blown head gasket i checked plugs, compressions, and even bought the Combustion tester kit and it stayed blue. The car runs great and doesn't ever get hot which was strange so i think i just had bad coolant. I'm bout to change out the water pump because it's making a strange noise. Could i drain the block of all that crap when I do that? I have the loudmouth as well and mine back fires a little when i gas it and am flying through the gears so i think that's normal.
06-02-2017, 08:01 PM #33
- Jun 2017
- Stamford CT
Black- 09 Chevy Avalanche 5.3
Dexcool is a demon when it comes to mix-metal heads. It does little to nothing when it comes to Steel block/steel head. Any other Mixture between block/heads/radiator and your're looking for trouble. Best bet is, "Water Wetter" or the Prestone universal. If you are mixing your own (not using 50/50 out of the bottle) try to use distilled water. Ive followed these guidelines through a ton of GM engine builds and I haven't had a problem.
Question: Coolant reservoir level goind down but no physical leak?
By JayTA98 in forum General HelpReplies: 10Last Post: 01-28-2014, 02:41 PM -
Coolant in PS reservoir 1999 SS
By armstroj in forum General HelpReplies: 4Last Post: 04-03-2010, 02:02 AM -
Coolant Reservoir size???
By MK1GTO in forum GTOReplies: 0Last Post: 07-01-2009, 05:19 PM -
Loosing Radiator coolant and milky colored coolant... what to do?
By JehalinTA in forum General HelpReplies: 23Last Post: 06-19-2007, 07:28 AM -
ls6 intake coolant plugs or extra front coolant pipe?
By mikes ss in forum External EngineReplies: 3Last Post: 12-03-2005, 04:13 PM
