TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
Afterthoughts Auto PerformaBuilt New Era Performance
Reply
Thread Tools
Old 01-08-2006, 10:56 AM   #1
ullose2
ullose2's Avatar
2000 transam
white/black stripes
trans. cooler inst. question?
does anyone know which is the return line from the radiator to the trans? Is it the line near the top of the rad or the one near the bottom so that I can correctly hook up the cooler. Thanks.
ullose2 is offline   Reply With Quote
Old 01-10-2006, 06:31 PM   #2
mrr23
The Multiple Moderator
mrr23's Avatar
1999 & 2000 formula
white & black
i completely bypasss the radiator when i do mine. might as well kill two birds with one stone. by not running the trans fluid through the radiator, the water is cooler going into the motor.
__________________
http://www.stealthram.com/familypics/rotatingsig.gif
mrr23 is offline   Reply With Quote
Old 01-10-2006, 06:48 PM   #3
mrr23
mrr23's Avatar
1999 & 2000 formula
white & black
i did a comparison of stock cooler vs external cooler bypassing the radiator.
i used a laser temp gun to get some readings of inlet temp and outlet temp. it ranged from 8-12* cooler. so, the radiator absorbs 8-12* of trans fluid temp. by removing it from the radiator, the coolant can now absorb that same 8-12* from the engine. remember, the trans cooler inside the radiator is on the side that goes into the motor. not the side that receives the water from the motor.
all the temp readings i took were sitting in park at the shop. engine temps 200*-215*.
cooler installed, radiator taken out of the loop. there was a 10*-15* drop in temps. this was engine temp at 215* sitting still in park on my lift at work. readings were in the 160* range for the tranny fluid temps going back to the tranny. while driving down the road, my engine temps were about 5*-6* cooler as seen on my scanner. so, killed two birds with one stone. no issue to be had with the not moving, not going through the radiator and no fans not cooling the fluid while sitting still theory. aluminum dissipates heat well. that's why radiators are aluminum now. used to be brass like the tranny fluid cooler you see in the pics. i'll try to take pics of my install tomorrow.
Reply
EmblemPros Autotrix T-Tops Online
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
