Results 21 to 27 of 27
Thread: Prothane poly motormounts
10-13-2008, 08:20 AM #21
- Feb 2006
- Seattle..Land of Constant Rain..
Red Fire- 2007 Mustang GT/CS
I did the Motor Mounts first. So they were new. Dunno Spaz, anything is possible.. but its sorta hard to fudge installation of the T mount. But Anything is possible... I still have a small shake in drive and the Prothane's have been in for 10 k mi's or more.. I replaced the T mount with new Factory and Instantly the rhythmic wham wham wham in drive at about 55-75 disappeared. Was is the T-mount.. Dunno I never put the Prothane one back in. Guess I should have We could have answered that question.
10-13-2008, 11:40 AM #22
10-13-2008, 01:28 PM #23
- Feb 2006
Hmm I will check the torque arm. Everything else is new and recent. I ran a Goodyear facility ( when the work was done. New Shocks and springs ( did the 1LE springs when I did the shocks.) Drive shaft is new cause my old one made a .. sproing.. sound when I hit the gas. That's OEM Chevy ( cause I am fussy) and yes it's aluminum. Torque arm... I never did check that.
Thanks for the thought. I will check that next time I rack the car.
10-13-2008, 01:44 PM #24
- Mar 2006
- WI
- Blog Entries
- 1
10-13-2008, 01:56 PM #25
- Feb 2006
I did a bit of Research on this when I was installing. And a few of the guys on LS1Tech.
Most said to install just the motor mounts an leave the tranny mount out. This was from the CCC guys ( run the 1/4s for points etc Ford Vs Chevy crew ) So I thought they knew what they were talkin about. I did do the tunnel brace with loop so I figured the drive line was re-inforced with that, the SFCs ( weld ins) and STB.
10-13-2008, 05:52 PM #26
Good mod,like the way drive train feels when I let the clutch out.
10-15-2008, 10:43 PM #27
- Apr 2006
- Chowchilla CA
White- 2001 Z28
A little vibration increase, but it smooths over time. Worth it if you have the engine out. I would not want to do this unless I was removing the engine for some other purpose. Just one more thing to do during the winter.
Question: Exhaust noise after Prothane Poly Tranny and Motor Mounts...
By manibot in forum External EngineReplies: 22Last Post: 12-07-2013, 01:53 PM -
BMR poly adj. phb AND aluminum poly boxed LCA
By xmarkx in forum Parts For Sale / TradeReplies: 3Last Post: 07-06-2010, 03:15 PM -
cause for bad motormounts?
By Ramairgod84 in forum General HelpReplies: 19Last Post: 04-09-2010, 08:30 AM -
LS1 Prothane Poly Motor Mounts
By SSpdDmon in forum Parts For Sale / TradeReplies: 0Last Post: 05-18-2007, 01:29 PM -
prothane poly rear swaybar bushings
By magilla in forum Parts For Sale / TradeReplies: 0Last Post: 01-30-2006, 10:07 AM
