LS1 Performance Information Kentucky-Speed TunedbyFrost T-Tops Online
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
Granatelli Motorsports TunedbyFrost Autotrix
Reply
Thread Tools
Old 01-06-2006, 10:33 AM   #1
rbob93
Senior Member
rbob93's Avatar
2000 CamaroSS
Sebring Silver
4L60E Output Shaft Seal Leak
What am I getting into if I replace it myself?
Any Special tools required?
Thanx, Bob
rbob93 is offline   Reply With Quote
Old 01-06-2006, 05:56 PM   #2
mrr23
The Multiple Moderator
mrr23's Avatar
1999 & 2000 formula
white & black
it's an easy replacement. hammer, screwdriver, and 11mm (7/16") wrench is about all you'll need. support vehicle safely to get under car. remove the driveshaft with the 11mm wrench from the rear. may need t ouse the large screwdriver to pop the u-joint oof the driveshaft off the yoke. slide out of trans. use screwdriver to pry out the old seal. use hammer to tap in the new seal. slide driveshaft back in. reinstall on rear. done.
__________________
http://www.stealthram.com/familypics/rotatingsig.gif
mrr23 is offline   Reply With Quote
Old 01-06-2006, 08:50 PM   #3
rbob93
Senior Member
rbob93's Avatar
2000 CamaroSS
Sebring Silver
Quote:
So nothing special, most like any output shaft seal that I've done over the years.
Thanx for the help.
Old 01-07-2006, 03:30 PM   #4
mrr23
mrr23's Avatar
1999 & 2000 formula
white & black
no problem.
Reply
LM Performance Third Shift Studios Mahle
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
