#1 |
Vig 3200
I just a Vig 3200. Anyone had experiance with one.
I was needing to know if I will need a tune or not to make car shift and run right. I have 3:73's and lid, headers, crapmaster and TSP mail order tune. Thanks. |
#2 |
SUPREME member-oderator
Veteran Member
99 B4C
Custom Slate Blue
Yeah you should tune it. TSP gives big discounts for mods to the tune if you used them for the first tune
#3 |
thanks man. Will proably try to make a 11 hour drive sometime in the spring then.
#4 |
Veteran Member
99 B4C
Custom Slate Blue
Where are you from? I live in Lubbock, about 3 miles from TSP
#5 |
I am from northeast AR. Little town named Pocahontas. Our closest city with a mall is Jonesboro which is an hour from here. Oh yeah I still live 2 miles down a gravel road. Sucks.
#6 |
I Hate Laser Radar
2001 Pontiac Trans Am WS6
Not to hijack this thread, but I have a question. Does a 2800-3000 stall have to have a "tune"? I thought these stalls were just installed and ready to run?
If you know, please let me know
__________________
Black 2001 WS6, A4, 3.23, Loaded, B&M Trans Cooler Debaffed sealed Airbox, Direct Flo Lid, K&N Magnaflow Muffler & Tips, Hotchkis Subframe connectors & Aluminum STB, Baer Eradispeed Cross-Drilled Rotors, Best 1/4 mi- 13.3, 107 mph, 1.9 60' |
#7 |
member since may 2000
Veteran Member
2000 nhra edition formula
the vig 3200 truthfully stalls up to 3600. its a good converter outside of the fact it feels alittle lose to me. a good friend of mine has the vig 3200 in his SS
__________________
2000 nhra edition formula a few bolt ons, 379 rwhp 11.96 @113.25 |
#8 |
The Multiple Moderator
1999 & 2000 formula
white & black
no. you do not need to tune for a converter.
__________________
#9 | |
Lawdogs bodyguard
Veteran Member
00 Black Ram Air Trans Am
414 RWHP 395 RWTQ
Quote:
What do you mean by the term loose? It's not comprehending in my pea brain what that means.
#10 |
1999 & 2000 formula
white & black
loose meaning you have to give the car more pedal to get moving. stock covnerter, you barely touch the pedal and off you go. with a higher stall comverter, it takes more pedal input to move the car. this is due to the design of the converter to stall higher. once you get to where the stall rating is at. it starts to revert back to a 1:1 coupling.
for instance: a converter with a 2.4:1 STR ( Stall Turn Ratio). the converter exterior will turn 2.4:1 times while the stator inside the converter the input shaft attaches to turns once. once you get to the stall rating and the car is moving, this ratio starts to decrease. best explaination i can give you. |
#11 | ||
1999 & 2000 formula
white & black
from Yank's site
Quote:
Quote:
#12 |
Lawdogs bodyguard
Veteran Member
414 RWHP 395 RWTQ
Thanks guys
#13 |
1999 & 2000 formula
white & black
no problem. that's what we are here for. well, that and raising our post counts.
#14 | |
Lawdogs bodyguard
Veteran Member
414 RWHP 395 RWTQ
Quote:
What |
#15 |
Lawdogs bodyguard
Veteran Member
414 RWHP 395 RWTQ
are
#16 |
Lawdogs bodyguard
Veteran Member
414 RWHP 395 RWTQ
you
#17 |
Lawdogs bodyguard
Veteran Member
414 RWHP 395 RWTQ
talking about?
#18 |
1999 & 2000 formula
white & black
about
#19 |
1999 & 2000 formula
white & black
post
#20 |
1999 & 2000 formula
white & black
whoring
| Bookmarks |
| Thread Tools | |
