Thread: swaybar rebuild
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    swaybar rebuild
    I want to buy all new bushings/endlinks for my 98 trans am(non ws6) what size is the front(30 i think) and what size is the rear sway bars?
    Will the front endlinks work on the rear endlinks?
    I plan on buying these from energy suspension
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    30mm front, 19mm rear
    Summit racing has everything you need. I'm in the process of doing the came thing. You will need to order a 2 3/8" end link set for the front swaybar.
    Prior to buying bushings for your front you might want to pick up a 'WS6' 32mm bar.
    They can be purchased from ebay (new/stiffer/hollow/lighter) for $20
    Marylandistan
    2001 Trans Am (sold)
    You can buy em at Autozone.
    SoDak
    White over Red
    1991 Suburban
    I just re built mine. The endlink bushings were pretty shot. I like the outcome. It leveled out the car in turns a noticeable amount. About perfect for my daily driver.
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Quote Originally Posted by thearborbarber View Post
    I dont know anything about the front sway bars,
    but the ones for the rear, when I was looking for some I saw them a little bit bigger like 32mm. Why do you say 19?
    Beaver Dam KY
    79 T/A -91 Firebird
    Mine are stockies!
    19mm stock w00t.
    SoDak
    White over Red
    1991 Suburban
    Quote Originally Posted by JwMonE99 View Post
    The front on the Z28's are 30mm and rears are 19mm. Just the way it is. Aftermarket units are easy to come by maybe that's what you have.
    http://www.stranoparts.com/partdetai...D=18&ModelID=7
    Here are the pieces I used to rebuild my factory units;
    http://store.summitracing.com/partde...5&autoview=sku
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    The front 1LE swaybars (WS6 & SS) are 32mm. For the rear there is a wider selection of sizes: 21mm, 22mm, 24mm, 25mm or 1" (25.4mm).
  1. Front swaybar help!
    By SSTODD in forum Suspension and Handling
    Last Post: 06-03-2011, 04:17 AM
  2. ws6 vs. ta frt. swaybar sizes
    By 70ssrag in forum Texas Members
    Last Post: 04-28-2010, 02:59 PM
  3. Question: Swaybar Advice
    By SteelCityTA in forum Suspension and Handling
    Last Post: 02-12-2009, 04:29 PM
  4. 04 Z06 Swaybar kit
    By BitViper in forum Western Members
    Last Post: 09-22-2008, 07:45 AM
  5. Swaybar
    By whiteta in forum Parts Wanted / Trade
    Last Post: 01-18-2008, 11:22 PM
