Results 1 to 2 of 2
    F-Body Genius Another WS6 Guy's Avatar
    Ft. Worth, Texas
    01 ECSB Z71 & 89 Iroc-Z
    LS1/LS6 Part Numbers!!!
    LS1/LS6 Part numbers...
    12160244 IAT Sensor
    24504388 IAT Sensor Grommet
    12480033 Hot Cam Kit
    10238852 LS1 Pushrod
    12552954 LS1 Timing Chain
    12559271 Water Pump Gasket (need 2)
    12561244 Front Crank Seal
    12557840 Crank Pulley Bolt
    12558013 Timing Cover Gasket
    12558573 Exhaust manifold gasket
    12559188 98-99 AIR tube (one side)
    12559189 98-99 AIR tube (other side)
    12556643 98-99 EGR tube
    12553047 EGR gasket
    12553617 AIR tube gasket
    12557932 EGR O-ring seal
    12560696 Valve Cover Gasket
    12565117 LS6 valve springs
    12560950 LS6 Camshaft
    12568002 LS6 Valley cover
    12658010 LS6 PCV kit
    88890523 LS6 Intake
    12568478 2001 Coolant pipe
    12562788 2001 Coolant plug
    10096163 Coolant Level Sensor
    12560744 "M-11" Headbolts (need 8/side)
    12560745 "M-11" short headbolt (need 2/side)
    12558840 OR 12558845 "M-8" Headbolts (need 5/side) *Not sure on which is correct*.
    12558809 Head gasket (drivers side)
    12558810 Head gasket (pass side)
    12556643 98-99 EGR Tube Assembly
    12556436 2001 Oil Pump
    16238212 Computer (PCM) 1998
    12177561 Engine harness 1998 (manual)
    25312196 RH O2 sensor
    25312197 LH O2 Sensor
    12558948 Coil
    12560228 Crank Sensor
    12560229 Cam sensor
    12555424 Belt tensioner
    10456603 Knock sensor
    9353691 Body Control Mod. (BCM)
    15301401 Coil harness
    25179711 LS1 MAF
    12160244 IAT sensor
    12552059 Water pump pulley
    25170361 Camaro lower airbox
    25179711 00' Mass Air Sensor (whole assembly)
    12561269 Intake manifold for 98-00 F-body
    88890523 Intake manifold for 01 F-body
    12557846 Intake manifold for 98-00 Y-body
    88890524 Intake manifold for 01 Y-body(LS1 & LS6)
    12560965 Camshaft for 98-00 F-body
    12560964 Camshaft for 98-99 Y-body
    12560968 Camshaft for 00 Y-body
    12561721 Camshaft for 01 F-body & LS1 Y-body
    12560950 Camshaft for 01 Y-body LS6
    12560194 Left exhaust manifold for 98-99 F-body
    12561308 Left exhaust manifold for 98-99 Y-body
    12559507 Left exhaust manifold for 00-01 F-body
    12562638 Left exhaust manifold for 00 Y-body
    12561255 Left exhaust manifold for 01 Y-body LS1
    12561256 Left exhaust manifold for 01 Y-body LS6
    12560193 Right exhaust manifold for 98-99 F-body
    12561309 Right exhaust manifold for 98-99 Y-body
    12559506 Right exhaust manifold for 00 F-body
    12562639 Right exhaust manifold for 00 Y-body
    12567706 Right exhaust manifold for 01 F-body
    12561256 Right exhaust manifold for 01 Y-body (LS1 & LS6)
    17113390 Throttle body for 98-99 F-body
    17113564 Throttle body for 98-99 Y-body
    17113647 Throttle body for 00-01 F-body
    17113669 Throttle body for 00-01 Y-body (LS1 & LS6)
    12533952 Injector for 98 F-body & Y-body
    12456154 Injector for 99-00 F-body & Y-body
    12482704 Injector for 01 F-body & Y-body (LS1 & LS6)
    12558807 Heads for 98 F-body & Y-body
    12559855 Heads for 99-01 F-body & Y-body (LS1)
    12560801 Heads for 01 Y-body (LS6)
    12480033 Hotcam for LS1
    Clutch/Transmission/Driveline
    12562765 LS1 Flywheel
    12560725 Aluminum drive shaft
    10085375 1LE Aluminium Driveshaft
    12570277 Clutch Master Cyl
    12570281 Z06 clutch, pplate, flywheel
    12562765 2001 Fbody clutch,pplate,fwheel
    12565145 2001 Slave Cyl
    15046288 2000 Slave Cyl
    22146231 1LE Transmission Mount
    12570281 Z06 clutch
    Suspension
    26032907 1LE front swaybar (32mm)
    10221779 1LE endlinks
    10021221 1LE rear swaybar (21mm)
    10262147 1LE Panhard bar
    22132887 1LE front springs
    22132889 1LE rear springs
    52367658 1LE Front Left Lower Control Arm
    22156461 1LE Front left upper Control Arm
    52367659 1LE Front Right Lower Control arm
    22156462 1LE Front Right upper Control arm
    10288551 1LE front swaybar insulator (32mm)
    10164151 1LE Lower Control Arms
    22166910 1LE Rear shock insulator retainer
    10009135 1LE Rear shock lower insulator
    22166909 1LE Rear shock upper insulator
    10235886 1LE Rear swaybar insulator (21mm)
    10413903 Torque Arm Bushing
    22174970 Transmission Mount
    Brakes
    18026165 Front brake pads
    12454972 Rear brake pads
    18038574 Durastop Disc Brake Pads
    18039370 Durastop Performance Disc Brake Pads
    18060230 Front Brake Rotor
    18060239 Rear Brake Rotor
    10434796 & 10434797 Brake backing plates (whole assembly w/ ebrake)
    18026160 GM Caliper Rebuild Kit (Note: 2 kits do one front caliper)
    Misc.
    12369966 SS logo (Silver)
    12369965 SS logo (Red)
    25121942 Fuel filter
    12378261 Diff oil for auburn
    12555685 Mobil 1 oil cap
    10236268 Mobil 1 sticker
    12556455 + 12559261 Fuel rail covers
    12564257 + 12564258 Z06 Fuel rail covers
    12457574 Ram Air Hood Stickers (White Metalic)
    12455211 WS6 Air lid "Ram-Air" Sticker
    12455209 WS6 Lower Air Box
    12455212 WS6 Lower Air box/radiator support
    12455213 WS6 Nostril Screen (1)
    12455214 WS6 Nostril Screen (2)
    12369963 SS Hood
    12369964 SS Hood grill screen
    12335525 Camaro Front Fascia
    10280356 Camaro Front Grille
    10193494 Camaro Front Fascia Emblem
    12369966 SS Side Emblems (Silver)
    9593624 WS6 Wheel
    9593305 WS6 Wheel
    10402860 Black Electric Antenna
    GMP00F Helms manual
    12369969 SS Spoiler Brake Light
    16799272 - Belt Guide RH - Passenger Side Seat Belt Guide Loop - Dark Gray Interior (98)
    16799273 - Belt Guide LH - Driver's Side Seat Belt Guide Loop - Dark Gray Interior (98)
    Thanks to Bayer-Z28
    good deal!!!
  1. Help: gm part numbers
    By 383ls6 in forum General Help
    Last Post: 04-26-2010, 05:33 PM
  2. 2 GM Part numbers please
    By grandkodiak in forum LT1
    Last Post: 04-28-2008, 01:49 PM
  3. GM part numbers.
    By y2khawk120 in forum General Help
    Last Post: 01-21-2008, 09:04 AM
  4. Part numbers
    By cordezzy in forum General Help
    Last Post: 08-31-2007, 09:23 PM
  5. Part numbers?
    By jasonlouis22 in forum General Help
    Last Post: 12-12-2006, 01:35 AM
