Thread: Procharger for a WS6 Trans Am
07-27-2008, 08:48 AM #1
- Jul 2008
- Mokena, Illinois
Navy Blue Metallic- 2001 WS6 Trans Am
Hi,
I want to get a procharger installed for my 2001 WS6 Trans Am and have a few questions...I rarely drive my car and bought it new..I currently have 17,000 miles on it with a few minor mods...It's an automatic transmission with Borla Exhaust and an aftermarket airlid...Anyways, I need some advice on what to get in order to get full output from a procharger...I was thinking maybe some new injectors, fuel pump and headers to compliment the procharger...I need some recommendations and what to buy along with the procharger to max out the procharger...Thanks, I hope to here from you soon!
07-27-2008, 09:43 AM #2
If you buy the kit, buy the D1 not the P1 cuz it only costs a few hundred up front, but it's a few thousand later on if you want to upgrade. It moves more air in the midrange.
You will not be able to max one out or close on a stock motor. If you pick an ET/MPH goal, it'll be easier to let you know.
The S/C will rewuire a different fuel pump, harness, and injectors. You will need a stall to get the RPMs up into an area where the centri is making boost for your automatic. Headers and a free flowing exhaust will be really helpful.
Don't forget the supporting mods like sub frame connectors to keep from twisting up the car, suspension mods to put the power down, and before long, a new built trans and a beefier rear end as they will only last so long being raced.
07-27-2008, 05:35 PM #3
- Sep 2007
- Lansing MI
Silver- 2002 WS6 TA
Look up exotic performance. They are located in IN. In 3-4 weeks I will be getting a D1SC. Best of luck to you.
08-14-2008, 09:57 AM #4
- Mar 2008
- multiverse
black- 1993 mustang
also get a transmission cooler if u plan on running it hard.
08-14-2008, 10:17 AM #5
- Jan 2006
- Shepherd, Michigan
wowzers..you will need a tune...You will also need to beefier injectors, fuel pump..headers are a must. also if you want as much as possible..you should upgrade your intake to a fast 92/92 WITH BURST PANELS!!! then like frost said a stall..with that stall a shift kit and a trans cooler..after that i would suggest getting some gauges to monitor a/f, trans temp and fuel pressure.
08-14-2008, 10:18 AM #6
- Jan 2006
You wont be able to push the S/c to the limit without forging your bottom end and also one can not forget..you would need heads and a FI style cam to really start pushing the S/c to its limits...
Wanted: Procharger Kit
By Deezl SS in forum Parts Wanted / TradeReplies: 5Last Post: 03-31-2011, 07:57 AM -
Procharger
By Jkerr27 in forum Forced InductionReplies: 42Last Post: 07-17-2009, 06:13 PM -
Procharger
By Texas Jack in forum GTOReplies: 33Last Post: 07-03-2009, 12:30 PM -
P1SC Procharger For 98-02 Camaro / Trans Am
By ls1bud in forum Parts For Sale / TradeReplies: 8Last Post: 10-24-2007, 08:56 AM -
Ebay: 1998 Trans Am D1SC Procharger + 402 stroker
By 98_firebird in forum Vehicles For Sale / TradeReplies: 0Last Post: 08-04-2007, 07:05 AM
