LS1 Performance Information Kentucky-Speed TunedbyFrost T-Tops Online
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
Zaino Granatelli Motorsports Holley
Reply
Thread Tools
Old 12-26-2005, 09:51 PM   #1
mike97ss
Guest
Posts: n/a
97 ss A4 shifting issues
first post on ls1. i would appreciate any opinions.
the 4L60 shifts very solid from first to second but will not engage at full throttle into third. i have to let off slightly to get it to drop into third. but when it does finally engage it does not slip at all and pulls well all the way through third and into 4th. this only occurs at full throttle and shifts perfectly under normal driving conditions.
the car may have 3.42's or 3.73's just got the car a month ago and have not had a chance to count the teeth on the rear end. could this be a pcm issue
if the pcm was not adjusted or tuned after the gear swap? i am not positive that the rear end has been modified but the mph to rpm ratio seems too high for 3.23's. or could it have more to do with the valve body?
thanks, mike
Reply
howellefi LG Motorsports TunedbyFrost
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
