TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
Autotrix Kentucky-Speed Cherry Bomb
Reply
Thread Tools
Old 12-22-2005, 08:27 PM   #1
98ls1blackbird
98ls1blackbird's Avatar
1998 Trans am
Question on 4l60e conveter
Hi everyone another new guy here. I've done several searches but cannot find an answer to this question. Hopefully someone here can shed some light. Is it feasable to use a converter out of an s-10 Blazer with 4l60e trans? I've tested several and they stall at 2000-2200 rpm, which is about 1000 rpm higher than in the v8's, I want to put it in my 98 Trans Am.
I'm an old school racer from years ago and we used to use th350 converters that came in vegas. It would stall about 3000 rpm behind a 406 small block. With a trans cooler I ran one for three years, street and strip, with no problems. I'm wondering if the s-10 or 4 cyl converter has been tried. Thanks. See ya.
Happy Holidays to all.
John
98ls1blackbird is offline   Reply With Quote
Old 12-22-2005, 08:36 PM   #2
Sarge
Let'sPartyLikeIt's1959
Sarge's Avatar
So many warnings we
made him a mod
Well I'lll be dating Jesse Jackson....finally another old junk yard gearhead!!! Shit man...before "JEGS" we lived at the junkyard cutting and beating shit to make our old 65 GTO's or 63 Chevy's a tad quicker.....ok...nuff of that I guess....
You could "rob" the stall out of another car...but I have a couple of thoughts first...have you programmed your shift points and firmness with what you have now?
Do that first....then a Precesion Industries 3200 stall is what you want man....2000RPM is not what gets the bar maid off if you know what I mean for your ride....
Sarge is offline   Reply With Quote
Old 12-24-2005, 11:04 PM   #3
nhraformula
member since may 2000
Veteran Member
nhraformula's Avatar
2000 nhra edition formula
the stock stall is 1800, its a waste getting what you want.
i suggest getting a tci verter. you can get a new one for about 450
__________________
a few bolt ons, 379 rwhp
11.96 @113.25
nhraformula is offline   Reply With Quote
Old 12-24-2005, 11:47 PM   #4
~redlinels1~
1998 Pontiac Trans Am
Dont waste your time trying to swap verters.
What are you future plans for the car? Is a cam in the near future? Match the cam to the verter and anything else you may get for the car. Im sure you know this, but you dont want a 2800 stall with a large cam.
If you're going to stay mostly stock, a 3000-3500 stall seems to suit most people quite nicely.
~redlinels1~ is offline   Reply With Quote
Old 12-25-2005, 09:33 PM   #5
98ls1blackbird
1998 Trans am
Thanks for the input guys. Just trying to explore all the avenues, I'll just get a good one to start off. As for mods probably at most a lid, converter, LT headers, ory, and cat back. I'm going to keep it mild and hopefully user friendly. Thanks again. See ya.
John
Old 12-25-2005, 09:48 PM   #6
nhraformula
Veteran Member
Quote:
John
with a 3000-3500 rpm converter and above mods, the car will run easy mid 12s and be driveable totally.
Old 12-26-2005, 04:24 PM   #7
98ls1blackbird
1998 Trans am
That's right where I want to be!!!!!!!!!!!!!!11
John
Old 12-31-2005, 12:17 PM   #8
mrr23
The Multiple Moderator
mrr23's Avatar
1999 & 2000 formula
white & black
I've done several searches but cannot find an answer to this question. Hopefully someone here can shed some light. Is it feasable to use a converter out of an s-10 Blazer with 4l60e trans? John
no. the LS1 f-body converter is different that all the other 4L60E converters. the 700R4, corvette LS1, and LT1 4L60E are the same.
mrr23 is offline   Reply With Quote
Old 01-03-2006, 11:18 AM   #9
maroonZ
Guest
Posts: n/a
Difference is?
What is the difference between the F-body and corvette converters?
Old 01-03-2006, 04:52 PM   #10
mrr23
mrr23's Avatar
1999 & 2000 formula
white & black
Quote:
the LS1 f-body transmission has a different input shaft than all the rest. so, hte converter is shaped diferently as well to accomodate it.
Old 01-04-2006, 09:33 PM   #11
redline
Sideways to da next light
redline's Avatar
2000 trans am
tci 3000 to 3500 stall is all you need bro.trust me i have a 3500 in mine and its my daily driver.but be safe and get an external cooler.
redline is offline   Reply With Quote
Reply
LM Performance T-Tops Online Rossler Transmissions
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
