Results 21 to 35 of 35
Thread: My LS1 SS got killed
06-04-2008, 07:25 PM #21
I wouldn't be so sure about that if I were you! My old purple pearl '93 made 439rwhp with an Advanced Induction combo - their 205cc heads, ported intake, and cam - on a forged 355 LT1. It is very possible with the right know how and combination to make that kind of power with an LT1. I met one of AdvancedInduction's customers at the F-body meet in Corona,CA last year with a 355 LT1, "streetable" Solid roller cam and A.I. combo that made 483rwhp. He is infact listed on A.I.'s web-sight (under the name "Alek") before the fix of intake manifold issues and new tune.
Also, here's a dyno graph of Russ Ethridge 355-powered N/A LT1, which produces 443rwhp/393rwt on 92 pump. He is also a customer of Advanced Induction and is listed in the testimonials page.
http://www.advancedinduction.com/Dyn...nowithMiss.jpg
View the testimonials for yourself.http://www.advancedinduction.com/AiPerfLT1.html
06-04-2008, 07:42 PM #22
- Aug 2007
- odessa,texas
69 hugger orange- 98 z28
nice rides,and nice death if you have to get beat at least it is by a beast of a ride
i agree with a few others, sneak off one day and install you a nitrous kit and then ask daddy if he wants a rematch
06-04-2008, 10:59 PM #23
- Jun 2008
- Garage
- 99 Trans Am WS.6
06-05-2008, 12:45 AM #24
I know all about AI, I'm running one of their custom cams. I was working w/ them to do a H/C package on the TBSS before I backed out, knowing I can't afford to blow the bottom end on my DD I owe 20k on...
Its not easy to make that kind of power on a 350 although it can certainly be done. And those 205 heads are top of the line race heads. You guys can claim DD all you want, bet you aren't DD'n em now....96 Imp SS- 12.74@103, 1.74 60' out of fuel
06 AWD TB SS- 12.58@106, 1.76 60'
01 Camaro SS- Totaled
06-05-2008, 12:52 AM #25
Just FYI, I drove my old '93 on a consistant basis looking for races. No it wasn't the best for daily driving, and no the 3600-stall didn't make it much better, but I could drive that car from one side of town to other - then back again with no problem. It saw way more street than it did track. Oh, and did I mention it made a hair under 440rw with the stock stroke?
06-05-2008, 06:09 AM #26
06-05-2008, 07:37 AM #27
- Apr 2008
- Mississauga, Ontario, Canada
Black- 2002 Camaro SS M6
well.... i was first clearing the intersection, he wasnt far back. i claim some good hooking and my light weight for a better launch.
as for his engine... the block was pulled from a 95 'vette. its not stroked. but he does have a stall on it (not sure how high... probably 3500ish). aftermarket performance cams (not sure of make), aftermarket crank (not sure of make), pistons (diamond), engine was bored out, bigger heads to accomodate bigger combustion chamber, ram air, LT headers (hooker ceramic, the only recent addition to his motor), edelbrock true dual cat back, catalytics taken out. posi rear end Heads and intake were ported and polished. engine was balanced, and tuned. he did the work himself in his shop on his machines. (except for dyno) and i am 99% sure that he has different gears in there, no way the stock 3.23's would pull like that.
Dyno said he was putting down 440... but we all know dyno numbers will vary from dyno and conditions its an approximate number. if its not 440, its pretty damn close.... either way, its not an easy car to beat. he took me.
as for being surprised that he got it moving at higher speed... you say you owned 2... but man, those things arent that great off the line, its at high speeds that they perform best. i mean, on freeways, you push down the pedal and the thing jumps. although they are pretty smooth rides, not rough like the f-bods. (but still, i wouldnt trade my f-bod for it)
06-05-2008, 09:26 AM #28
06-05-2008, 10:57 AM #29Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
06-05-2008, 05:07 PM #30
Stock 3.08s. We didn't get 3.23s.
My car will cut a 1.6x in good wx w/ a low end robbing cam in it. They get off the line dude.
BTW, N2O, mine aint no DD. I can drive it easily, but don't like to. I'm going to eventually pull the heads and send them to AI. Expect to put down around 380 on a stock crank.
06-05-2008, 06:12 PM #31
06-05-2008, 06:28 PM #32
06-05-2008, 09:35 PM #33
06-05-2008, 10:32 PM #34
Traction is a major issue in the cars believe it or not. I have zero traction at anything in first gear in mine. I'm just surprised his Imp pulled that hard up top on the LS1.
06-09-2008, 06:32 AM #35
Killed a SRT-4
By Y2K_CAMARO in forum Kill StoriesReplies: 30Last Post: 10-27-2008, 06:06 PM -
killed an sti
By blue02Z in forum Kill StoriesReplies: 21Last Post: 05-27-2008, 03:53 AM -
GTP......killed
By blackhawk01 in forum Kill StoriesReplies: 17Last Post: 12-14-2007, 06:55 PM -
Evo killed me
By JHayesLS1 in forum Kill StoriesReplies: 57Last Post: 12-03-2007, 02:23 PM -
Something funny happened, then got killed and killed today !
By Speedy_Gonzales in forum Kill StoriesReplies: 3Last Post: 10-17-2007, 07:39 PM
