    North America
    1999 Trans-Am
    Subframe conectors?
    Is it true the verts came with sub-frame connectors from factory? I was sorta browsing around for some for my 99 and found that mentioned on a vendors site.
    Member 99'CajunFirehawk157's Avatar
    39466 USA
    Bright Red
    99 Firehawk #157 Roadster
    FALSE, I added UMI bolt on...
    Regards,
    Todd
    #cajunhotrodder on instagram
    retired racer not 4 long chevy1966's Avatar
    mississippi
    red white
    1999 z28 vert 1998 z28 ht
    BMR weld on's here! Wow, what a difference. Best addition yet.
    Junior Member Deep6Hicks's Avatar
    Daytona Beach
    2000 Z28 vert
    Same here, I have the weld in sub frames and I had to ditch the K member for clearance on the exhaust. Can't tell a difference without that k member. Sub Frames definetly make for a stiffer ride.
    North America
    1999 Trans-Am
    How much, if any, clearance did you lose?
    I've got stock exhaust and it jist tickles the ground as I go in and out of my parkade if they're any lower than that I forsee problems.
    I'd really like to add them, hopefully they'll help keep the car tight longer.
    Orig Regist: 9/98
    NE Indiana
    1998 Trans Am WS6 'Vert
    Quote Originally Posted by Wheels View Post
    The factory-supplied 'vert-unique reinforcement under the floor pan ("K" member some have referred to above) is commonly mistaken as a "sub frame connector", it's is NOT. While it does stiffen the floorpan to resist twisting, it doesn't come close to the function or performance of a real SFC.
    Johnny B - '98 "Triple Black" WS6 Convert, M6, All Options, ASC #3030 (1 of 50)
    KBDDSFC, DGM C/F Tonneau, MTI C/F Lid, K&N, HPP-III, 160 T-stat, Pro 5.0
    Link to Firebird Production Breakdowns
    Member Z ROADSTER's Avatar
    Shreveport,Louisiana .USA
    PEWTER
    2002 Z/28 VERT.
    Factory bracing was intended to allow for a smoother ride . If you want a MUCH stiffer ( READ,rougher-jigglie ) ride then by all means go ahead and install the sub-frame connectors . The down side includes , less ground clearance,much harsher ride quality, added extra weight , power to weight decrease , less MPG . Take your choice .
    Daytona Beach
    2000 Z28 vert
    I can't really tell how much you might lose, mine is lowered two inches front and rear (compliments of the previous owner). My exhaust hangs below my sub frames, so I actuley didn't lose anything from the sfc's. Measure the difference between the lowest "scratch point" and the frame, then just find something that will fit in that space.
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    Quote Originally Posted by Z ROADSTER View Post
    Factory bracing was intended to allow for a smoother ride . If you want a MUCH stiffer ( READ,rougher-jigglie-squeaky ) ride then by all means go ahead and install the sub-frame connectors . The down side includes , less ground clearance,much harsher ride quality,promotes squeeks & rattles . Take your choice .
    I don't see how subframe connectors promote squeaks & rattles; if anything, they decrease the squeaks/rattles....and many SFCs "tuck" into the underbody, so you lose little, if any, ground clearance....
    Midwest Member Topless TA's Avatar
    Kansas City Suburbs
    WS6 M6 Vert
    (Factory bracing was to reinforce the body since the there is no roof)
    I have them along with a STB
    the ride in no way suffered it is much more responsive
    and flex under hard excel is now limited
    clearance is no issue they tuck nicely and the y-pipe actually hangs lower
    I would highly reccomed them for an Fbody vert
    (now lowering springs that might be a diffrent story depending on the rates)
    Member BlackSS1's Avatar
    Lexington, NC
    2001 Camaro SS Vert
    Quote Originally Posted by Topless TA View Post
    I agree, the ride is firmer with less squeaks and rattles since the chassis is sturdier with reinforcement - squeaks come from stuff flexing and rubbing.
    The firmer ride is GOOD becase these are performance cars. Since the frame is not twisting and flip-flopping, the suspension can do its job properly and control the body motions. The benefit to handling is really great.
    Junior Member Thunda's Avatar
    Albany,Ga
    2001Ws6 TransAm
    What is the general idea, belief or recommendations about SLP subframe connectors? bolt on.
    2001WS6 T/A slp lid, smooth bellows, Taylor Thundervolt wires, Bosch+4, Vig 3200 stall, BM trans cooler, SLP 3" Y-pipe, 3" corsa catback, preditor custom tune by RWTD, 275/17BFG'S. 1976T/A 455-4spd-3:42
  1. SLP Bolt in Sub Frame Conectors
    By BRICKYARDDTX in forum Suspension and Handling
    Last Post: 06-05-2011, 05:24 PM
  2. subframe connectors???!!!
    By dadowd in forum Convertible
    Last Post: 05-12-2010, 07:25 PM
  3. subframe connectors
    By kthmc33 in forum Suspension and Handling
    Last Post: 08-11-2008, 01:54 PM
  4. (UMI) Subframe connectors
    By Richy_Rich67 in forum Suspension and Handling
    Last Post: 08-02-2008, 08:58 AM
  5. Replies: 0
    Last Post: 05-12-2006, 10:37 AM
