TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
Autotrix EmblemPros Zaino
Reply
Thread Tools
Old 12-20-2005, 11:03 AM   #1
Chromess
Royal Purple tranny fluid? Which one?
Im going to be switching what fluids I can over to RP fluids. I was wondering what I should run in the tranny. The book specifies Dexron III automatic fluid. RPs sight lists manual trans. fluid(Syncromax) when automatic fluid is specified or auto trans fluid(Max ATF) when Dexron III is specified. So should I use the max atf? Also does Max-gear work with all rearends?
Chromess is offline   Reply With Quote
Old 12-20-2005, 11:28 AM   #2
SteveC
Retired NOT tired
SteveC's Avatar
2001 Z28 (Sara)
SOM
I have read posts on various boards that discourage the use of synthetic fluid in the 4L60e transmission, I would stick with the Dexron III.
SteveC
SteveC is offline   Reply With Quote
Old 12-20-2005, 07:30 PM   #3
02 super sport
2002 Camaro SS
I'm about to run royal purple in my tranny and in my rearend tomorrow, I'll let you know how it turns out. As long as you get the stuff that says that it replaces Dexron III thats the right stuff, I'm getting 75W-90 gear oil, it has the required additive for limited slips.
02 super sport is offline   Reply With Quote
Old 12-21-2005, 07:09 AM   #4
Tobynine9
Witty Phrase
Tobynine9's Avatar
1966 427 Cobra Replica
Burple
My transmission guy says you shouldn't use Dex III. He says use the Synchromesh (RP's version of Synchromesh is Synchromax). I've got Synchromax in mine and it's working great.
Tobynine9 is offline   Reply With Quote
Reply
LG Motorsports Kentucky-Speed T-Tops Online
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
