Results 1 to 20 of 21
08-14-2005, 09:26 PM #1royalking03Guest
advice on swapping a v6 for a v8?
This is my first post to this site. i have a 2002 camaro coupe with a 3.8L v6 automatic. And i miss the rumble of a v8. So ive asked around and everyone so far has told me to just go trade for a v8 camaro. i hope this isnt the best advice i can find. please can someone tell me what v8 would fit and be best for me. i only want it for back and forth to work and the occasional adrenaline rush. please someone point me in the right direction. p.s i dont think any of those other guys knew that im still making payments on my car and its a pain to go the trade route also.
08-15-2005, 12:38 PM #2
- Westminster, Md
NBM- '99 Z28
buy a V8 its the easiest thats what i did. By the way your V6 has a 3.8 not a 3.6
08-15-2005, 06:16 PM #3royalking03Guest
thats good advice but what type of v8 will fit and what kind of mods will i have to make?
08-15-2005, 07:03 PM #4
You can do it yes.
Even if you get an LS1 motor (v8) complete with harness and PCM, there always seems to be electrical issues such as no gauges, ac, radio etc. and check engine lights.
For some reason the headlights always work.
You really need to know where every single wire codes in color with what.
Even with the painless wiring from painless wiring.
I have heard of guys having to change the entire wiring in the car to make for a correct swap.
If you are patient .. and I mean really patient .. yes it is a good swap especially if you like your car.
Otherwise trade for an LS1.
08-16-2005, 10:03 AM #5
- Westminster, Md
NBM- '99 Z28
i meant buy the Z28 or SS it is the easiest thing to do the swap ia alot of work
08-16-2005, 01:36 PM #6quicky06Guest
the easiest and probly cheapest would be to sell your car and get a v8. if you want to swap the easiest would be to get a a carborated crate engine(no harness to mess with. and then theres the ls1
08-18-2005, 10:57 AM #7
Cabreurated is the way to go if you are going to actually do this, but you are still going to have issues with some of your electrical/ computer stuuf because of all the lacking sensors. if u go to an ls1 it would take you forever it would create more problems than a mechanically inclined car owner could actually handle.. the engine and transmission, wiring and computer will run you around 3000 to get a good complete set.. and after you do that it will take you hours.. it would be better to take a little loss on your trade than to spend extra in $$ AND HOURS OF TROUBLE SHOOTING AND LATE NIGHTS.. good luck with whichever u choose..
08-18-2005, 03:33 PM #802-35th-ssGuest
I have done a swap not so much as technical as this would be but I have a 87 lx mustang {came with the 6cyl} and dropped a 5.7l 451w all carberated the issues i have with a car that is not dependant on electronics are, Tach is way off {the v8 makes more sparks than a 6 cyl so the gage is off. The front suspension had to be beffed up because the old iron 351w is alot heavier than the little old 6cyl. I blew 1 trans {i keeped the stock one in till it blew, I knew it would happen} Id say I have one of the meanest sleepers where I live. It was alot of work but i took out all electronics other than my oil pressure and water pressure.
08-20-2005, 02:00 PM #9
idk man a mustang cant really be a sleeper, especially with the V8 drone at idle
now a eclipse or talon with a huge turbo intercooler, etc.... is a sleeper
we have a lot of ricers like that around here in CT, and some of them are serious such as an older galant with 360 RWHP, not to say if you spent the same amount of money into a V8 you wouldnt kill it
08-21-2005, 05:04 PM #10royalking03Guest
there is an ls1 crate angine @www.crateenginedepot.com complete with wiring harness and computer for $6000. would this engine be a good buy and would it solve all the technical problems you say i would have? and thank you all for all the advice!
08-21-2005, 07:30 PM #11
just get a huge turbo for the V6 and you'll eat on stock ls1's untill u blow it
08-21-2005, 08:38 PM #12
Honestly, swapping an LS1, or even an LT1 into your Camaro would be a huge headache. You'd have to change springs, fuel lines all wiring ect... it's been discussed at length on the various v6 boards. Even if you got the engine in and everything, I can't imagine it would be very reliable at all, not to mention like the others said, the various annoyances like some of your electronics not working and things like that. Plus for the cost, and all the work, and stress, it just plain wouldn't be worth it. Now if you're simply looking for the power of an LS1 in your 6, it's not that hard to achieve, and would be way cheaper than an engine swap, while retaining the driveability of a daily driver. However if you're dead set on that V8 sound specifically, cost wise, I'd say go look for a used LT1 and throw some bolt on's on it. They're affordable enough right now. That's probably your best bet.
1997 Firebird 3.8L
A4,WS6 Ram Air Hood, Edelbrock Catback, SLP CAI, 85 Dry Shot
1981 Firebird Trans Am
http://members.cardomain.com/dreaded_hope
08-21-2005, 10:37 PM #13
It's been done, I swapped an LS1 out for a V6 in my old Camaro and if I had to do it all over again, I'd just buy the V8. But if you'd like some info send me a PM and I'll send over some info that will be of help.
08-22-2005, 06:38 PM #14royalking03Guest
what is pm?
08-22-2005, 06:55 PM #15royalking03Guest
thanx for all your help everyone!
08-23-2005, 03:01 AM #1602-35th-ssGuestOriginally Posted by ss~zoso~ss
08-26-2005, 09:59 PM #17Spartan_AngelGuestOriginally Posted by dreaded_hope
Seriously, unless there is some extremely unique situation that you do NOT want to sell that car or buy a new one...then it would save you money, time, frustration, and even performance just to upgrade the car itself. If you bought an SS not only do you get the V8, you get suspension, wheels, tires, drivetrain, and even long term value improvements over the V6 model. Even if you bought the SS and then modded it instead of the V6, you'd still come out ahead in every category.
08-23-2008, 03:00 PM #18
- Aug 2007
- saginaw MI
Blue- 2000 Camaro SS Convertibl
I would sell your v-6 (to a privete buyer, not a dealer, they'll screw you on the price). I bought my SS from a guy you was still making payments on the car, and the whole transaction toke us about 15 minutes going through his lender that had the lein on his car that he was selling to me. Basicly I paid his bank for the full selling price then the bank put the money in his account for the difference. For example, I bought the car for $15K, he still owed the bank $5K, I then paid the the full $15K to the bank, his bank then deposited $10K into his account, and then signed the title over to me. Really, the transaction isn't that complicated, and your lender will walk you through everything. Yeah, it's definately easier and cheaper in the long run to sell the V-6, and go out and buy a decent Z28 w/ an LS1. If you're buying this car as a daily driver MAKE SURE it's an LS1 engine, not the old LT1...you'll get much better fuel economy (not to mention performance) with the LS1 engine.
I've bought a "slightly" overpriced SS SLP convertible myself, but honestly the Z28's w/an LS1 has to be the best bang for the buck car out there, and has almost identical acceleration as the SS...just not as mean looking!
08-23-2008, 03:05 PM #19
dude you can get a pretty cheap LS1 car now anyways
08-23-2008, 09:08 PM #20
- Feb 2007
- San Diego, CA
Why did you ressurect this ancient thread??????? It's originally from 2005.....
Question: LS1 , swapping
By Butch2000 in forum General HelpReplies: 17Last Post: 03-24-2010, 08:18 PM -
Help: Swapping an LT1 for an LS1
By LS194Z28 in forum Camaro / SSReplies: 13Last Post: 07-23-2009, 07:02 PM -
advice for swapping in an LS1
By nuttyprofessor in forum Classic MuscleReplies: 4Last Post: 12-11-2008, 01:38 PM -
SWAPPING LS-2 with LS-1
By dvdslw in forum Internal EngineReplies: 4Last Post: 08-17-2007, 06:00 PM
