Results 1 to 20 of 34
04-30-2008, 04:39 PM #1
- Pittsburgh, PA
Loud squeeling brakes after new pad install
Here is a vid. this is with the pedal at rest and the system bled. WHY are they making this sound, and WHY can i push on my caliper does it seem to loosen the grip? The rears do this a little bit but it's not as loud of a sound, and i can't jiggle them at all....
04-30-2008, 06:06 PM #2
- Nov 1999
- over here...
that is nothin duder... just go down the road at 30mph... hit your brake and the gas to maintain speed and do it for 10 seconds... let off and cruis a bit so they can cool then do it again... they should be fine after that... it's jsut the pads need to seat in to the rotors...
04-30-2008, 06:09 PM #3
- Pittsburgh, PA
omg, for real?? i'm about to bolt up the rims and go for it
04-30-2008, 06:18 PM #4
04-30-2008, 06:28 PM #5
first off, what kind of brake work did you perform.
04-30-2008, 06:31 PM #6
04-30-2008, 06:39 PM #7
- Pittsburgh, PA
mushy pedal after the drive, still continued to squell @ 15 mph. no leakin fluid-resevoir is still toped off
04-30-2008, 06:43 PM #8
- Pittsburgh, PA
removed calipers and replaced pads. I compressed the pistons before reinstalling the calipers. yesterday i was blowing fluid all over the place upon depressing the brake b/c i didn't have solid contact with the brake line to the caliper-now everything is tight. i just bled all corners until i saw fluid
04-30-2008, 06:54 PM #9
dude, maybe im interpreting it wrong....but you didnt COMPLETELY remove the calipers to replace your pads did you? It might be a stupid question, but you shuoldnt leak any fluid at all jus sliding a caliper off and compressing pistons.
Also, did you have your rotors resurfaced or did you replace them? You wanna "bed" your new pads to a new rotor surface. ie resurfaced or new rotors. When i say bed, i mean a series of stops from about 35 mph to 10 or so. step firmly and progressively. do it about 10 times and you should be good. and please make sure those brake lines are tight on your calipers lol
05-01-2008, 04:52 AM #10
- Pittsburgh, PA
i drove it about 4 miles to the shop. It grinded LOUD the whole way. I maintained a whoping 15mph. It was midnight when i did it so no cars were on the road. I pulled off the road once to inspect and noticed the rotors were hot as hell. I sat for 5 minutes then went again-once i got there they were significantly cooler for some reason? It was only 40° last night so that probably had a lot to do with it. But i'm just not good with this diagnosing shit when i know a shop could do it . Thanks for all your help!
05-01-2008, 05:11 AM #11
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
Jaison, do you think you put a pad in backwards by accident?
05-01-2008, 05:19 AM #12
05-01-2008, 05:21 AM #13
05-01-2008, 05:22 AM #14
- Aug 2006
- Baton Rouge, La.
QuickSilverMetallic- 2005 GTO M6
Or he could have a caliper freezing up on him and not releasing all the way. If you installed new rotors did you have them turned also? Thats always a good idea, mass produced rotors tend to be a tad out of round also.
05-01-2008, 05:24 AM #15
05-01-2008, 05:45 AM #16
- Pittsburgh, PA
YES I HAD THEM TURNED
it's primarily the front ones that seem to be dragging? clinging? collapsed? dunno...but they were loud as hell
05-01-2008, 05:48 AM #17
05-01-2008, 05:55 AM #18
- Pittsburgh, PA
Like i said, i dropped it off with a shop. I got a friend there who will do most of the work on his own time
05-01-2008, 06:12 AM #19
05-01-2008, 10:02 AM #20
- Pittsburgh, PA
no-wasn't aware that i had to do that? I was basically going off of install university's page-so if they didn't say it, i didn't do it
Brakes are spongy after Line Lock install...
By ls1camino in forum Suspension and HandlingReplies: 2Last Post: 07-04-2009, 01:06 PM -
loud squeeling
By tingo99 in forum External EngineReplies: 10Last Post: 03-31-2008, 09:48 AM -
New Brakes install!
By Demon_Z28 in forum Suspension and HandlingReplies: 13Last Post: 03-01-2008, 09:03 AM -
Loud ticking noise after cam install
By gunguyWS6 in forum Internal EngineReplies: 8Last Post: 11-01-2007, 04:05 PM -
Loud thump after UMI torque arm install
By topfig1 in forum Suspension and HandlingReplies: 9Last Post: 08-05-2007, 05:39 PM
