TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
T-Tops Online Nelson Performance Afterthoughts Auto
Reply
Thread Tools
Old 11-30-2005, 04:56 PM   #1
MxMike458
1999 Camaro
Reverse/park Please Please Help!!!!!!
I was driving home from work and when I got home I went to put my car in park and the button on top of the shifter would NOT move, I can get the car into reverse if I push down really hard on it and move it into position. Since i cant get it into park I cant get my keys out. Does anyone know what could have happened?! This car is nothing more than a daily driver. I figured yall might know what is wrong. Its a 1999 Camaro RS. Please help! Thanks alot
-Mike
MxMike458 is offline   Reply With Quote
Old 11-30-2005, 05:12 PM   #2
LS1-450
Take the cover off of the shift lever handle & see if the spring is jammed. The shift button will pop right out & you should be able to push the mechanism on the top of the shift lever straight down, by hand. If the top of the shift lever will not push down (after removing the handle), then something may be wrong inside the transmission.
LS1-450 is offline   Reply With Quote
Old 11-30-2005, 05:36 PM   #3
MxMike458
1999 Camaro
Thanks alot! I will try that tomorrow right after school, I sure hope that works. Oh well, Maybe I can get a T56 installed now if my tranny is broken.
Reply
Hotparts PerformaBuilt Pedders Suspension
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
