TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
EmblemPros PerformaBuilt Autotrix
Reply
Thread Tools
Old 08-12-2005, 11:24 AM   #1
99BlkLs1
Guest
Posts: n/a
Trans Mount Install
I have a 99 Trans am A4 that has a broken trans mount. How do I install a new mount.
Thanks,
Will
Old 08-12-2005, 11:44 AM   #2
AnotherScreenName
2001 Camaro
SOM
Real easy, should take about 20 minutes. Jack the car so you can get under it, use a small jack to support the tail of the tranny. Unbolt the mount from the crossmember, jack up the tranny a little bit so you can easily get to the two bolts holding the mount to the tranny. Take out the old one and put in the new one in reverse order.
AnotherScreenName is offline   Reply With Quote
Old 08-12-2005, 11:44 AM   #3
Zboner
Senior Member
Veteran Member
Zboner's Avatar
99 SS
take the crossmember out from under the car and take the old trans mount off and put the new one on. its extremly simple
Zboner is offline   Reply With Quote
Old 08-14-2005, 02:37 AM   #4
hfldTA
Guest
Posts: n/a
Re: Trans Mount Install
install university.com
Old 08-20-2005, 12:12 PM   #5
Herz28camaro
Herz28camaro's Avatar
1995 Z28 Camaro
I have to replace mine as well
1995 z28 Camaro
where would I purchase one and how much do they run
thanks in advance guys
Deanna
Herz28camaro is offline   Reply With Quote
Old 08-20-2005, 01:53 PM   #6
Hurley711
Lawdogs bodyguard
Veteran Member
Hurley711's Avatar
00 Black Ram Air Trans Am
414 RWHP 395 RWTQ
BMRfabrications.com $20 or so I think mine was
Hurley711 is offline   Reply With Quote
Reply
New Era Performance LG Motorsports Fast Toys Performance
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
