Page 1 of 4 1234 LastLast
Results 1 to 20 of 62
    Make real real sure Johns00Z28's Avatar
    Germantown, MD
    2000 Z-28
    Roller rocker question
    I was looking at these roller rocker arms http://www.granatellimotorsports.com...lerrockers.htm on granatelli's website. They claim 8-11% more hp and 10-15% more fuel efficiency. Is this total BS or are these valid claims?
    Aug 2000
    Indy
    most are skepticle of thier claims
    Germantown, MD
    2000 Z-28
    Do you know if they give any hp or any help in fuel efficiency? Basically I'm wondering even if they don't make what they claim, would it still be a reasonable upgrade and be worth their price?
    Vote for Pedro.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    youll gain some h.p, not much. maybe 5 rwhp
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Germantown, MD
    2000 Z-28
    So pretty much the money could be better spent doing another mod?
    Alien Baby FuriousGeorge's Avatar
    Feb 2006
    Tinker AFB, Oklahoma
    Midnight Blue
    seems like they're usually pretty high on their claims...sorta like SLP
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    Quote Originally Posted by Johns00Z28 View Post
    Exactly right.
    05 PBM GTO
    Cold Air Inductions CAI,
    Relocated IAT with omega,
    Slp Predator tune,
    Flowmaster axle back with H pipe,
    Custom tuned TCM.
    BC Racing coil overs
    Sold 01 z28
    depends on what you have done now... they will give better gains down the road with other mods...
    Germantown, MD
    2000 Z-28
    Well I don't have anything done at the moment. Just looking for a few mods I can start with.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    if you want rockers that work, then get the vinci/crane accelerated lift kit. used the 1.8 rockers on the wife's car on stock cam and picked up 17 rwhp. the kit is $669.00 through vinci. comes with rockers, posi-locks, guide plates, screw-in-studs, and shorter pushrods.
    Germantown, MD
    2000 Z-28
    That's a pretty impressive gain! What other mods does she have? Is that a relatively easy swap?
    orlando, fl
    2014 camaro 2ss/rs
    lid, filter, MAF ends, bassani headers and catted y-pipe, borla exhaust. not too hard to do.
    Dec 2002
    n/w chicago
    1.8 rockers will limit what kind of cam a person can get in the future. i advise against it.
    i had 1.85 rockers and sold them when i was about to cam the car.
    Germantown, MD
    2000 Z-28
    Quote Originally Posted by nhraformula View Post
    Why would that limit the cam you could use? Would it be more advisable to just upgrade the rockers when you do a cam swap?
    orlando, fl
    2014 camaro 2ss/rs
    just means don't buy a thunder racing cam. so long as you have proper piston to valve clearance and spring control, going to larger ratio rockers will not limit you in cam choice
    orlando, fl
    2014 camaro 2ss/rs
    here's some actual dyno and track tested data to ponder over. vinci did a comparison of a comp cam and their cam. Project C5 AFR
    comp cam 224/224 .581.581 (1.7 rockers) 115 LSA vs vinci 055 cam 216/224 .583/.583 (1.8 rockers) 113 LSA
    http://vincihighperformance.com/beck...20tricker.html
    the smaller cam with higher ratio rockers made more overall power. now, which would you rather have? and these cams were tested with the stock torque converter.
    Dec 2002
    n/w chicago
    piston to valve clearance. you cant get moderate and above cams with a 1.8 rocker arm unless you fly cut the piston.
    Dec 2002
    n/w chicago
    that means you cannot buy alot of proven cams, not just thunder.
    to top it off, thunder doesnt make their own cams, comp cams does.
    Dec 2002
    n/w chicago
    i cam post dyno graphs of big cams on stock rockers making more power.
    hell, just go to ls1tech.
    orlando, fl
    2014 camaro 2ss/rs
    comp grinds thunder's specs for them. just like crane grinds vinci's cams for them.
    just because you haven't heard of them, doesn't mean they are proven.
  1. Question: Has anyone done the roller rocker upgrade?
    By TheJudge05 in forum GTO
    Last Post: 03-28-2010, 06:39 PM
  2. Roller Rocker Help
    By WS6ICK in forum Internal Engine
    Last Post: 09-06-2007, 03:33 PM
  3. Roller Rocker advice
    By LSXWS6 in forum Internal Engine
    Last Post: 06-29-2007, 03:29 PM
  4. Roller Rocker Ratio
    Last Post: 09-16-2006, 08:52 AM
  5. Roller Rocker Arms
    By lonewolf37 in forum Internal Engine
    Last Post: 07-05-2006, 06:34 PM
