#61 |
2002 Pontiac Trans Am
Burgandy
alright, cool.. how do i get that checked out to make sure its right? just take it to a mechanic?
#62 |
I lika da Chevy's
Z/28 LS1
BLACK
I personally wouldnt even worry about it. I would only be concerned if it was extremely low pressure. What weight oil did you put in your car? If its higher then 5-30 then that can make the pressure go up.
#63 |
Burgandy
the car was serviced by the dealership just before i bought it so i am unsure on the oil weight. Since i bought i have only put not even 2000 miles on the car. I am going to take it in here soon. Any recommendations on the oil weight or anything like that, that i should be using?
#64 | |
Miss Pennsylvania
01 WS6 Midnight Blue
'98 Black Gone :(
Quote:
#65 |
I lika da Chevy's
Z/28 LS1
BLACK
If you live in a very hot area like Florida I would go with 10w-30. 5w-30 if you live anywhere else. My car has 70,000 miles idles at 40psi and goes to 50-55psi while driving. But just to ease your mind-even 80 oil pressure would be find. I wouldnt worry one bit. Dont lose any sleep over it man. Youre fine.
#66 |
Burgandy
Well i live in Socal, So we get out hot spurts but in my part of town i still get the cool ocean breeze ever so often so usually hardly ever over 90-95..thanks for the input and help guys
#67 | |
Cummins > Powerstroke
98 Z28
Blue A4 3.42
Quote:
or using to heavy of an oil. |
#68 |
I lika da Chevy's
Z/28 LS1
BLACK
Yea could be overfilled or too heavy oil used by mistake if you are taking it to get the oil changed. Those guys fuck up thats for sure. They forgot to put oil in my sisters car when they did a oil change-its sad but true.
#69 |
Burgandy
how?? lol. i cant picture someone being so dumb at their job that they can forget to put oil in a car while doing and oil change...
#70 |
98 Z28
Blue A4 3.42
#71 |
2000 Trans Am
This just started the like 2 days ago, this only happens when the car has been driven for more than a hour but when its been running for a while it stays just above 40psi and then moves from like 41 to 45 and then back down again it just keeps moving a little. Only at idle when drving its moves like normal but at idle it moves slightly about 4-5psi. Anyone know why this is i heard it could be low oil and it picking it up but the oil is fine about 6-6.5 quarts still.
#72 | |
I lika da Chevy's
Z/28 LS1
BLACK
Quote:
#73 | |
I lika da Chevy's
Z/28 LS1
BLACK
Quote:
* you have to be a dumb MF not to put oil back in a car when changing oil. |
#74 |
98 Z28
Blue A4 3.42
true that. lol.
#75 |
1998 Pontiac Trans AM
I would personally buy a cheap $15.00 Oil Pressure gauge to check the levels. It might not even be the sender.. Worst case scenario your main bearings are destroyed.. But a lot of LS1's are known for their oil pumps to go out.. Causing extensive damage if not destroying it. So.. If you want to play it safe... Check it out.. Replace the sender if it's the case.. (usually if it's the sender your oil gauge will be erratic). If it's the pump.. Which in my TA I've already replaced the pump for insecurity issues.. Get it taken care of, or you will regret it. I'd recommend the SLP oil pump.
#76 |
I lika da Chevy's
Z/28 LS1
BLACK
^ I had the sending unit go bad in my car and it read just like it would read normally except very low pressure. It would read 20psi when it was cold and 10psi when it got hot. I put a new one in and it reads 60 psi cold and 50 psi hot.
| Bookmarks |
| Thread Tools | |
