Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #41
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i have updated the link in the original post as i have moved the pages to a new website
    http://tredalign.com/hptuners.htm
  2. #42
    Glad you bumped this -- I have never seen this thread before.
  3. #43
    Feb 2011
    ny
    2006 ls1
    need tune
    i have the 515 trick flow top end kite in my ls1 motore and the 92mm fast intac and throutel. i just bought an HP tuner but i dont know how to tune Any help? i tuning file maybe?
  4. #44
    Junior Member MeanGreen98's Avatar
    May 2010
    Martinsburg,WV
    Med. Green Metallic
    1998 Camaro
    awesome
    Great Resource!!
  5. #45
    Jun 2012
    columbia station ohio
    07 Chevy Corvette
    2004 Pontiac GTO
    With hp tuner pro. Is it 1 credit per car each time you tune the car or can you tune that car as many times as you want. I was thinking about getting it. Dont know how many credit i would need. I have a gto, 07 vette and an 05 escalade. I am going to be purchasing a trans am this winter. So do i need 4 credit or would i need more.
    2004 Pontiac GTO
    2007 Chevy Corvette
  6. #46
    you will need 8 total credits to tune all 4 as those are all 2 credits each......once you marry their vins to the cable you can flash those cars as many times as you want. Since your cable comes with 8 credits you won't need to buy any more credits unless you add vehicles beyond the 4 you have listed.
  7. #47
    Junior Member sloroller's Avatar
    Apr 2010
    al
    01 camaro ss
    mrr23 thanks for posting this hp tuner info this made the decision easy to make with the assistance fo thels1 site.
  8. #48
    orlando, fl
    2014 camaro 2ss/rs
    good to see that as of yesterday i am seeing people using this guide. checked my website stats yesterday. still in the top 5 positions of referrers.
  9. #49
    Arizona
    Wow, I thought you went extinct
  10. #50
    It's good info.
  11. #51
    Aug 2009
    Tulsa, Oklahoma
    Anything LS1's - LS6's
    Your have posted some good info in this thread but there are so many new tuners here that need to know its not wise to make some changes in the PCM without the use of a WideBand. Take PE tables for instance...If the MAF Is not calibrated after say a CAI, and you go to simply try to rape the PE table with math, and just because the math is commanding a 13.0 AFR...you could actually be running 13.5 -14 AFR at WOT and not know it until its too late. There is a certain method to this tuning madness so I advise the new tuners to take your time and do a lot of research before jumping in and changing values. I think for the sake of newbies, maybe you should split up your info between basic tune mods and advanced. That is just a suggestion.
    Any Tulsa Oklahoma area new tuners can just PM me for 1 on 1 help anytime. I'm like Mrr23, I do it because I'm an LSx gear head, not for money.
    Steve
  12. #52
    Junior Member 86MonteSS's Avatar
    Mechanicsville, VA
    Primer Grey
    86 Monte SS
    Very nice for us newbies to tuning....
    86 Monte SS w/98 LS1 A4. Z06 Intake, MTI B1 cam(221/221, .558/.558 - 114 LSA), Manley springs and retainers, Grannetelli 85mm Mass Air, stock TB, Hooker LT headers, 12.64@112 on street tires.
  13. #53
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    What you have put together is a great help for us DIY tuners. Thank You very much!
    Any more additions coming?
  14. #54
    orlando, fl
    2014 camaro 2ss/rs
    Haven't really touched hptuners since I sold the formula back in 2007.
    I do have a 2000 corvette now
    So I might start back up.
  15. #55
    Apr 2015
    illinois
    1999 z28
    i am looking for a tuner, the only requirement is i want to have the ability to block codes so i can smog the car without fixing the a.i.r. pump. ive found one made by Jet Performance, looks great, but im nervous about tuning without having some preset starting point. any ideas??? its a budget project and will not be modded, aside from the slp airbox.
    - - - Updated - - -
    and yes, i read the "handhelds vs....thread already"
  16. #56
    frost does a mail order tune for $150. tunedbyfrost.com
  17. #57
    ^^ This. In a addition to adjusting the error reporting codes, he will tweak your tables and other settings. I have run a Frost mail order tune in our car for years.
  1. a tuning guide i found based on hptuners
    By mrr23 in forum Computer & Tuning
    Last Post: 08-23-2022, 08:58 PM
  2. Android 4.2: A visual guide to what's new
    By Ed Blown Vert in forum Computers / Gaming
    Last Post: 11-23-2012, 11:50 AM
  3. Visual differences between ls1 and ls6 engine?
    By pbguy357 in forum Firebird / WS6
    Last Post: 06-05-2011, 09:35 AM
  4. visual help
    By V8MUSCLE in forum Wheels and Tires
    Last Post: 07-24-2009, 11:49 AM
  5. Possible Visual Mods
    By JoshieDoom in forum Appearance Section
    Last Post: 11-17-2007, 07:11 PM
