Thread: No power to diagnostic port?
04-12-2007, 02:55 PM #1
Just went to Autozone to have them pull the codes on my car to see if I have anything other than the obvious rear 02 and EGR codes. Well there is no power to the diagnostic port. The guy said it runs on the same fuse as the lighter. Honestly I had no clue if the lighter worked or not. It does not. Which is the fuse for it and is it true the diagnostic port runs off of that fuse as well? Thanks.
04-12-2007, 03:43 PM #2
- Jul 2005
- Jacksonville, FL
Check the CIG/ACCY fuse inside car.
04-12-2007, 05:39 PM #3
04-12-2007, 09:15 PM #4
the cam position sensor is in the back of the block behind the intake next to the oil pressure sending unit. look on the right side of this pic. you'll see a black object. that's it.
D-Port Cylinder Heads - D-Port Development
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 12-14-2010, 08:30 PM -
Direct Port Nitrous - Plumb Like A PRO - Nitrous Power!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-24-2008, 06:30 PM -
Help ! Diagnostic Port
By Y2KblueZ-28 in forum Computer & TuningReplies: 2Last Post: 08-30-2007, 07:56 PM -
diagnostic help
By blackbeast in forum Computer & TuningReplies: 2Last Post: 12-07-2006, 07:41 PM
