#1 |
2000 Camaro Z28 A4
Sender for trans temp guage
What kind of fittings do I need to mount the sender in the pan? Any other options ?
#2 |
Retired NOT tired
2001 Z28 (Sara)
SOM
If it is an automatic transmission, there is a pressure port on the side of the case above the transmssion linkage, the size is 1/8 NPT. I get very accurate readings from that location.
SteveC
#3 | |
2000 Camaro Z28 A4
Quote:
Is there tranny fluid at that location? I don't want to read case temp. |
#4 |
Retired NOT tired
2001 Z28 (Sara)
SOM
I really do not know the answer to that, however the reading I get there is within 1 degree of what auto tap says it is.
SteveC
#5 | |
Quote:
Yes, there is. There was fluid on the plug when I removed it to mount the sender in that location. |
| Bookmarks |
| Thread Tools | |
