Results 81 to 100 of 125
01-29-2007, 05:40 AM #81
- Dec 2005
- Research Triangle Park, NC
Pewter- '99 Z28 M6
Hey Angus, that is the trick for making a car really fly. Guys will be quick to shoot down the idea of removing crap we might need out of a car. A/C system is the big one that everybody craps on.
"Oh man, you took off the A/C, what were thinking?"
I was thinking, I never use it, it drains 5 rwhp, and it weighs about 100 lbs. Other than that, its really COOL.
You take about 200 to 300 lbs off a car, and it is like adding a 75 shot of nitrous to it. (guesstimation)
01-29-2007, 05:53 AM #82
- PA
Grey- 2003 Mach 1
Cecil is a track known for producing high MPH, no matter what the make/model car.
My own experiences + those of other drag racers seem to support that fact in general.
FWIW, I ran an 11.46 @ 118.33 MPH about a month later at Atco.
Here's the vid:
Atco 11.46 @ 118.33 MPH
118 MPH is a more realistic indication of the kind of MPH my car can hit at a good track.
My race weight isn't that low yet either - there's still 175 - 250 lbs I could drop if I really wanted to get serious...
01-29-2007, 07:07 AM #83
- Dec 2005
Pewter- '99 Z28 M6
All you really need is the driver's seat and the steering wheel anyway!
01-29-2007, 08:03 AM #84
Well if he car is completely gutted with the right gearing and tires. I could see low 11's even if he is only making 330 - 335 hp but also he never said that is what he is making. All Angus did indicate is that is a stock Long block. He could have a crazy set of cams an intake and headers and probably make more than 335 hp also the heads, although stock casting that dont mean that they arent ported/polished (but he did say stock).
01-29-2007, 08:18 AM #85
According to Motortrend's Oct '05 issue they tested an '06 Corvette Z06 and ran 11.5 in the 1/4. Now everyone knows and especially Mustang Guys know that MT cant Drive a car for s***. Think back to 2003 - 2004 MT Couldnt get a Cobra to run better than 13 maby really high 12's but MM&FF magazine ran low 12's high 11's without as much as even lowering the tire pressure in the back. So yes (no offence) it is questionalble if Angus has "No Trouble" with new z06's
01-29-2007, 08:54 AM #86
- PA
Grey- 2003 Mach 1
My Mach made 335 rwhp & 342 rwtq the last time it was dynoed N/A.
"Stock Long Block" to me means that the engine has never been opened-up for any reason other than to change the oil.
I have stock unported heads, stock cams, stock valves, stock pistons, stock rods, stock crank & stock bore/stroke - my engine has never been apart.
My Mach is also not "completely gutted" or even close to "gutted" - it still retains power windows/locks/tilt/cruise/airbags/carpetting/interior panels/etc.
All of my body panels are also just as they came from Ford - no lightweight hood/trunk/fenders/doors/etc.
The absolute quickest stock C6 ZO6 (on stock tires) that I'm aware of went 11.2 in great air with one of the best drivers in the country. I personally have yet to encounter a C6 ZO6 that ran close to that ET.
01-29-2007, 05:51 PM #87
HMMM, Interesting...
Check this site out. Dynoperformance.com. Of nineteen 2003 to 2004 Mach 1's tested only one broke the 300hp mark and that was an '04 with 8lbs of boost. He made 384 HP and 375 lb/ft. The next closest one was an '03 that only made 291 HP and 317 lb/ft. You can see more info on these dyno runs by clicking on the "View" button on the right. I am going to assume that all of these motors are "stock long block" considering the numbers. What are you hiding from everyone Angus, you may as well go ahead and tell everyone because not many people are believing you. The only thing that is left is headers (didnt see anyone on that site with headers) and headers usually don't make up 50 some odd HP. I dont doubt your 1/4 mile time b/c like I said before the right gears and tires can do wonders.
01-29-2007, 07:17 PM #88
- Jan 2006
- Ohio
Here's the vid:
01-29-2007, 07:41 PM #89
- Nov 2006
- Maryland
White- 1994 300ZX Twin Turbo
01-29-2007, 07:44 PM #90
01-29-2007, 08:03 PM #91
I have 302 RWHP and is stock weight and I dont know what it would run in the 1/4 but I know it would not run better than low 13's and John Force couldnt make the car that much faster just because he is a good driver. a couple 10th's maby (which is an eternity in racing) But yall are talking more than a second.
01-29-2007, 08:04 PM #92
- PA
Grey- 2003 Mach 1
I wouldn't exactly call 19 dyno tests (out of 16834 Mach's produced between '03 & '04) a representative sample - that's only .1% of the Machs produced and it's only at one dyno shop in California (a state known for marginal-quality gasoline & you can only get 91 octane).
Here's my dyno graph from my Mach when it was 100% stock (paper air filter/stock exhaust/stock tune/etc):
(The lower line was my 2001 Cobra for comparison)
Just for fun, I dynoed it again after adding a drop-in K&N air filter and Mobil 1 oil:
After adding a cold-air kit, complete exhaust and a dyno tune, rwhp was up to 327.
I then added a ported intake manifold & hit 334.5 rwhp:
I'll also add that the last dyno run was made with 4.30 gears in the rear.
More aggessive gears can & do rob about 5 - 7 rwhp compared to more "Mileage-Friendly" 3.27's or 3.55's.Last edited by Angus66; 01-29-2007 at 08:09 PM.
01-29-2007, 08:10 PM #93
01-29-2007, 08:13 PM #94
- Jan 2006
- Ohio
Your entitled to your opinion too
And I definitly see your point. A famous quote I like is "Believe nothing of what you hear, and half of what you see." (Ben Franklin or Mark Twain, I can never remember which.) Anyhow, I used to be a Chevy fan, then I drifted to Ford for awhile, now I've drifted back to where I can honestly say I love a good fast Chevy or Ford; I just don't care. (* Oh yeah, Dodge sucks*) Hey, if the guy says he drives an 11 second Mach, has a video, and doesn't seem like a major ass in his posts; why give him shit?
01-29-2007, 08:15 PM #95
01-29-2007, 08:18 PM #96
01-29-2007, 08:23 PM #97
01-29-2007, 08:28 PM #98
- Jan 2006
- Ohio
Well I am gonna have to take a dump here in a little while, so I will get the other 16815 dyno results to you when I am done...
01-29-2007, 08:30 PM #99
...OK
01-29-2007, 08:33 PM #100
- Jan 2006
- Ohio
Fox1x read this post again please... I never questioned his 1/4
SD boys know HP.....
By suede in forum Almost Anything GoesReplies: 10Last Post: 01-18-2009, 09:35 PM -
Hey boys!!!
By MySiLvErGtO in forum New Member IntroductionsReplies: 11Last Post: 10-02-2008, 08:48 PM -
God among boys!!!
By Common in forum Almost Anything GoesReplies: 22Last Post: 01-17-2008, 08:43 PM -
12-1 boys!
By 02sunsetorangeZ in forum Almost Anything GoesReplies: 24Last Post: 12-11-2007, 05:10 AM -
Hi boys!
By HotForumAChick in forum Almost Anything GoesReplies: 60Last Post: 05-11-2006, 01:15 PM
