TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
Pedders Suspension 6LITEREATERDESIGNS EmblemPros
Reply
Thread Tools
Old 09-28-2005, 09:28 PM   #1
Ghost Rider
1985 Chevy Impala
Gold
Transmission pan leak
Ok,
I have a 700R4 in my '85 Impala. The transmission pan has had an annoying one drop leak for about a month. The old gasket was obviously shot so I decided to replace it. Unbolted the pan, drained the fluid, cleaned off all the old gasket material and put the new gasket on (looks like it's made of rubber. Got it from O'Reilly autoparts) and bolted the pan back on. Refilled with 4 quarts of fluid. two days later, it's leaking again. Drop here. Drop there. Figured I didn't tighten the bolts up enough, so torqued them some more. Still leaks. Put in some Prestone ATF Stop leak. Checked it tonight. Still leaks. Looked underneath and can see the edge of the gasket is wet with fluid. I checked the fluid level after I got home (30 minute drive) and it isn't overfilled, so that's not it. The pan didn't look damaged or warped. My next option is either a new OEM style Steel pan (with drain plug) or a B&M Chrome Steel Deep Pan (with drain plug)I found at Pepboys. With either pan, the drain plug will make future fluid changes easier. The Deep pan comes with a gasket that is probably of a higher quality than the one I got from O'Reilly. I've heard that the deep pan increases cooling ability. Assuming I replace the pan, is the deep pan better? Any thoughts on my pan leak? It's leaking on the driver's side back edge. Nowhere else.
Ghost Rider is offline   Reply With Quote
Old 09-29-2005, 10:13 AM   #2
Ghost Rider
1985 Chevy Impala
Gold
Bump. Anyone?
Old 10-01-2005, 03:48 PM   #3
WALLst AL
WALLst AL's Avatar
00 Corvette
Torch Red
Deep Dish Pan
The only thing I can add is, yes it does keep the fluid a little cooler especially with a tranny cooler, also I have a high stall converter. I have had mine for several years works great, recommend one for all automatics.
__________________
00 Corvette
Perf Mods:
WALLst AL is offline   Reply With Quote
Old 10-01-2005, 06:27 PM   #4
Ghost Rider
1985 Chevy Impala
Gold
Well, it's unanimous. Deep dish pan forthcoming.
Meanwhile, I decided to drain and unbolt the pan again and replace the "rubber" gasket with a "cork" gasket and replace the filter while I'm in there. Lesson learned. Thanks for the Input. I love Vettes (one of the few two seaters I can fit in), but there's nowhere for the kids to sit, hence my big ole full size Chevy.
Old 10-15-2005, 01:33 PM   #5
02 Mag Red
02 Coupe
Mag Red
Check and see if it is leaking from the vent tube on top of the trans , you might need a trans cooler.
Joe
02 Mag Red is offline   Reply With Quote
Reply
T-Tops Online Afterthoughts Auto Rossler Transmissions
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
