TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
PerformaBuilt EmblemPros Pedders Suspension
Reply
Thread Tools
Old 09-26-2005, 06:30 AM   #1
02_WS6
2002 WS6 Trans Am
I'm going to put a Stall and shift kit
In my 02 WS6 and i was wondering what would be the best products to get. This is a daily driver. Also is there any supporting mods i should do as well? Also if possible could you guys give me some links on places to find these things so i can get an idea on costs. Thanks a ton for your help.
Marc
P.S. If I do this to my car, all i will have done is this (stall, shift kit) and BG ram air and slp air lid, and cat back exhaust, will be able to beat a 99 Z28 camaro with long tube headers and heads, and a 87 Iroc with exhaust, cam, heads? Thanks again.
02_WS6 is offline   Reply With Quote
Old 09-26-2005, 10:48 AM   #2
BlackHawk T/A
Got LS1 Envy?
BlackHawk T/A's Avatar
2001 WS6
The 99 Z28 will smoke you, and you will most likely beat the 87 IROC.
In your scenario:
Z28 > You > IROC
Though we don't know what kind of heads/cam the IROC has.
BlackHawk T/A is offline   Reply With Quote
Old 09-26-2005, 10:58 AM   #3
BadBlueBird*
Feels so good
BadBlueBird*'s Avatar
1999 Trans Am
Medium Blue Metallic
Go with AT LEAST a 3200 stall, Vig and TCI make get stall and most of the time you can get a used one for around $400
You may suprise that z28!
BadBlueBird* is offline   Reply With Quote
Old 09-26-2005, 11:11 AM   #4
Ed Blown Vert
Blown, Stroked, & Sprayed
Ed Blown Vert's Avatar
383 Procharged & N20 Vert
Don't forget some Nittos to hook with that Stall.
Ed Blown Vert is offline   Reply With Quote
Old 09-26-2005, 11:23 AM   #5
onyx_rock
Quote:
x2
onyx_rock is offline   Reply With Quote
Old 09-26-2005, 12:52 PM   #6
2001NBMZ28
Senior Member
Veteran Member
...and a tranny cooler.
2001NBMZ28 is offline   Reply With Quote
Old 09-27-2005, 06:46 AM   #7
SteveC
Retired NOT tired
SteveC's Avatar
2001 Z28 (Sara)
SOM
You might want to consider replacing the weak flexplate they installed in th 01 & 02 vehicles with a TCI unit.
SteveC
SteveC is offline   Reply With Quote
Old 09-28-2005, 10:06 PM   #8
00BlueTA
1SlowTA
00BlueTA's Avatar
2000 Trans Am
Blue
Just really quick with the stall's is there a reason i see different spline? how can you tell what you have or are the 4l60e all 30?
TIA
-00BlueTA
00BlueTA is offline   Reply With Quote
Reply
Zaino Fast Toys Performance Cherry Bomb
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
