Thread: Removing EGR and Air Pump
08-12-2006, 12:12 AM #1
I am in the process of adding Long Tube headers and LS6 intake to my 2000 Trans Am, WS6, LS1 and I want to remove the EGR system and Air Pump. Does anyone have a link with instructions on how to remove them and what to remove?
Thanks
08-12-2006, 12:40 AM #2
It's pretty basic and self explanitory once you get started. The EGR is all up top so you can just pull it off and since you're putting in the LS6 intake on there's no holes to plug unless you're headers have the emissions provisions then just put a block off plate on it which can be bought at several sponsors or you can easily make your own.
The air pump itself is under your drivers side headlight( you can get to it from the bottom of the car through the access panel). Just pull it out and unplug it and remove all the tubing going to your manifolds and block those off as well. Also, pull the fuse for the air pump so that you don't have live wires hanging anywhere.
After you do these mods there are a few codes you'll have to turn off in the pcm to keep from getting an SES light. They are:
DTCs for AIR
P0410
P0412
P0418
P1415
P1416
DTCs for EGR
P0400
P0401
P0402
P0404
P0405
P1406
P1409
If no one else writes a full blown "how to" on pulling these before tomorrow I'll write you one up. I just got home from work and it's very late. I believe once you look everything over real good you'll see that both are pretty self explanitory.
I would like to add one other thing. When I pulled my EGR I also had to adjust my timing tables because I started to get some knock. It seems that some people have this happen and other people don't. From what I've read it seems the majority don't have this problem but I did. I went from nothing to around 7 degrees of KR when going WOT from mid throttle cells. I calculated my where the knock was happening and smoothed that part of the table and all was good again.
08-12-2006, 10:42 AM #3
Yes I plan on using the Non-EGR and Air Long Tube headers from Pacesetters. PCMFORLESS does my tune so they will cancel out everything so the SES light does not come on. I just wanted to know what I need to take off when I remove the EGR and Air systems. Your write up will help alot.
Thanks
08-12-2006, 04:27 PM #4
"I would like to add one other thing. When I pulled my EGR I also had to adjust my timing tables because I started to get some knock. It seems that some people have this happen and other people don't. From what I've read it seems the majority don't have this problem but I did. I went from nothing to around 7 degrees of KR when going WOT from mid throttle cells. I calculated my where the knock was happening and smoothed that part of the table and all was good again."
Thank you Orion-a month or two ago when I suggested this as a possibility there was more than one knot head on here that laughed their asses off. I mean they went ape sh@t!! They probably won't read this as they are off somewhere stuffing their heads up their collective @sses. It's good to see someone on here up on real tech.
Question about removing the EGR and the air pump
By Big Block Bobby in forum Computer & TuningReplies: 0Last Post: 03-25-2012, 09:09 AM -
removing egr and air
By jmatt07 in forum General HelpReplies: 7Last Post: 03-12-2009, 07:18 AM -
Power Steering pump leak?! new pump or seal kit?
By JehalinTA in forum General HelpReplies: 2Last Post: 03-18-2008, 10:05 PM -
Removing the AIR and EGR
By Madcity T/A in forum External EngineReplies: 20Last Post: 08-02-2007, 02:16 PM -
Fuel Pump Pump Problem?????? Help!
By undertakersT/A in forum General HelpReplies: 4Last Post: 04-24-2006, 09:55 AM
