TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
Afterthoughts Auto Kentucky-Speed Zaino
Reply
Thread Tools
Old 09-08-2005, 05:28 PM   #1
02_WS6
2002 WS6 Trans Am
Question about stall converter
I have an automatic transmission in my WS6. All i have done to it performance wise is dynomax bullet mufflers and Edlbrock shorties. Now if i added a stall around 2500 rpm, what kind of performance gains do you think i would see? Would it be as fast as a Manual WS6? What kind of track times do you think it might run? I just wanna know if it is worth doing or not. Thanks a ton in advance.
Marc
02_WS6 is offline   Reply With Quote
Old 09-08-2005, 05:30 PM   #2
Ed Blown Vert
Blown, Stroked, & Sprayed
Ed Blown Vert's Avatar
383 Procharged & N20 Vert
A stall is one of the best and first mod you should do to an A4. But don't get anything less than a 3200. And whatever you decide, go one higher.
__________________
Forged 383, ATI D-1SC
NX MAF Kit, 222/226 .585 115
AS Stage II 6.0L FI Heads
548.0 RWHP - 536.8 RWTQ - 10# - D1
Black 2008 GMC Yukon Hybrid 4WD
DDM 55w 5000k HID Hi/Lo
GMX-322 LockPick
WeatherTech Cargo Liner
Gunner 6 20" Wheels
Ed Blown Vert is offline   Reply With Quote
Old 09-08-2005, 05:58 PM   #3
Sarge
Let'sPartyLikeIt's1959
Sarge's Avatar
So many warnings we
made him a mod
A stall will add more than nitrous.....ED is correct...3200 minimum will plant them M6 boys in the cabbage patch Seriously consider a transgo shift kit and a BM trannie cooler.....
__________________
This is my signature. It is mine. Nobody else has one like it.
Sarge is offline   Reply With Quote
Old 09-09-2005, 11:44 PM   #4
BlackHawk T/A
Got LS1 Envy?
BlackHawk T/A's Avatar
2001 WS6
How about mileage on a daily driver?
If you get a 3200 stall doesn't that pretty much negate your 0-3100 rpms and make you run 3200+ RPM all the time? That would be a little harsh...
Or am I wrong?
BlackHawk T/A is offline   Reply With Quote
Old 09-10-2005, 09:45 AM   #5
ice
Guest
Posts: n/a
I have heard someone talk about a "shift kit" but can someone explain the stall converter. What it does, where it goes on the tranny, how much are they?
Old 09-10-2005, 10:32 AM   #6
Ed Blown Vert
What will a higher stall torque converter do for my car?
A higher stall torque converter will multiply the torque of your engine to put more power and torque to the tires! The high stall torque converter will “slip” the engine into a higher rpm range where there is more torque and horsepower. This will make your car haul ass!
What kind of performance gains will I see with a high stall torque converter?
Our customers typically see a .5 reduction in quarter mile times, traction permitting. Highly modified cars with ported heads and bigger cams have seen gains of over 1 second!
What will happen to my fuel economy?
Very little. If your vehicle originally came with a lock-up clutch, your Yank Performance Converter would also have a lock-up clutch. You may need to apply slightly more throttle for driving around town, but you should not see a noticeable drop in fuel economy.
Reply
Nelson Performance 6LITEREATERDESIGNS Autotrix
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
