TunedbyFrost
Go Back   LS1 Performance Information > LSx Technical Help Section > Drivetrain > Automatic Transmission
Online Store Sponsors Rules
Notices
New Era Performance Hotparts Rossler Transmissions
Reply
Thread Tools
Old 09-07-2005, 04:22 PM   #1
the-f'in-kid
1998 camaro
blue
Help separating Trans from engine
The ls1's have 9 bolts holding the bellhousing of the 4l60e to the engine. The problem i have run into is that the dowel does not want to separate itself. The dowel is causing the transmission to remain connected to the engine. Simple methods of wiggling the transmission with a jack underneath have not worked, nor has pry bars and bottle jack pushing against trans towards differential. Has anyone ever run into this problem and how would i go about correcting this? The transmission needs to be separated or else there is no way to service the transmission. Any Ideas?
the-f'in-kid is offline   Reply With Quote
Old 09-07-2005, 06:22 PM   #2
sscrazy
sscrazy's Avatar
00 camaro ss
Quote:
try a hammer and wedge! I have a manual trans and when I pulled it out i couldnt get it seperated from the bell housing, I actually cracked it. The dowels have a spiral design on them wich makes it really hard to get out. I would suggest getting about 2 or 3 people under there and try wiggling a little harder. it will come out....
sscrazy is offline   Reply With Quote
Reply
PerformaBuilt LG Motorsports Pedders Suspension
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
