Results 41 to 60 of 97
11-11-2008, 08:32 AM #41
11-11-2008, 08:35 AM #42
11-11-2008, 09:16 AM #43
11-11-2008, 09:24 AM #44
11-11-2008, 09:34 AM #45
AAR lightweight radiator support $200
Pulleys $300
Short belt $50
Shorty headers $350
off road x pipe $200
OEM clutch $0? unless replaced
Aluminum flywheel $250
Weld 15" wheels $500
1 piece steel driveshaft $250
Front and rear lower control arms $150
Roush springs (modified by AAR) $250
Stock original shocks and struts
Line loc $100
Short throw shifter $150
2 step launch control ? no clue
Cold air intake (Modular Depot) $300
SCT x-cal2 tuned by AAR $200
IMRC eliminator plates (not port matched) $250
4:56 gears $200
GT 500 throttle body $300
AAR lightweight rear brake assembly $250
Light weight front brake assembly $250
Slicks and skinnies $600
Battery in stock location (Not OEM battery) $100
3200 pounds with driver
1 Kirkey seat $150
$5350 and i think i was being quite fair?
11-11-2008, 09:37 AM #46
- Oct 2007
- Lake Tahoe, CA
Cayenne Red, Pewter- '97 Z28 1LE #53, '02 WS6
Ehh, if your referring to the '99-04 GT, no 2-valve stang is going to hit 11's with bolt-ons! No friggin' way!! High 11's takes ported intake, heads, cams, all the nick nacks plus suspension/gears. And even then i've seen several guys still linger in the very low 12's at around 109-111. 11's takes a lot of work in a 2v if you wanna do it naturally aspirated.
11-11-2008, 06:02 PM #47
11-11-2008, 06:07 PM #48
Of course you can skew the numbers by using all high numbers. 300 for pullies?? come on now.
umm no it doesnt. People are running high 11s with stock heads, cams and standard bolt ons. You guys really need to get off the internet and learn about pony cars.
11-11-2008, 06:13 PM #49
- Jul 2007
- tennessee
TA-White, Camaro-Black- Track-TA98A4 DD-98z28M6
there were quite a few things he went cheap on.. gears for 200... and you stil got to get them installed.. 600 for slicks and skinnies, with rims it would be more like 800..
Pulleys $300
Short belt $50
Shorty headers $350
Line loc $100
4:56 gears $200
1 Kirkey seat $150
11-11-2008, 06:15 PM #50
11-11-2008, 06:17 PM #51
11-11-2008, 06:23 PM #52
11-11-2008, 06:28 PM #53
- Oct 2007
- Lake Tahoe, CA
Okay there's two people. I still wan't to 'see' proof (i.e. write up, video) of a two-valve going 11's bolt-on only in a 99-04 body. The 11-second N/A cars i've seen over the years have all had full mods...meaning everything touched, including suspension, tires and weight reduction. I'm hard pressed to believe 11's with just bolt-ons. For example, the fastest naturally-aspirated 2v GT wen't 11's with h/c/i.
11-11-2008, 06:30 PM #54
Ive been off the internet and been to many drag race events, 99-04 GT's with standard bolt on's will not hit 11's at all not even close. If you consider nitrous a bolt on and juicing alot, motor wont last with really good suspension along with tires and gears, MAYBE. When i say nitrous you can guess it wont be 100 shot. Not to put down the mustang but a car that pushes about 220-230 rwhp with LT's headers, no cats, exhuast, intake and tune they push about 250-260 rwhp tops, with about 150 shot of nitrous which should put them about 380 whp give or take depending on tune and other factors with really good tires and good gearing and a great driver you might hit 11's but its all a guess and from what i know for a fact regular bolt on mustangs do not hit 11's. To go 11's is not just having power its a combinations of many things, cant just dump a bunch of power in a car and not do suspension work amoung other things to get you there. I dont mean no disrespect but i know what ive seen and although there not slow cars its alot of time, money and effort going 11's for those cars.
11-11-2008, 06:34 PM #55
11-11-2008, 08:50 PM #56
I think an 11 sec NA GT between the years of 96-04 is more of a rarity than the norm. http://www.musclemustangfastfords.co...out/index.html
11-11-2008, 08:56 PM #57
11-11-2008, 08:59 PM #58
11-11-2008, 09:06 PM #59
- Oct 2007
- Lake Tahoe, CA
Because the GT is a totally different animal. 4.6 Two-valves do not respond well to bolt-ons, which is typical for a small displacement engine. True it takes more than just horsepower. Suspension, drivetrain, weight reduction etc. play a part. But those motors just aren't stout enough to get the job done. From my experience with these engines, the examples you see in the attached MM&FF article is what it really takes to run 11's N/A.
11-11-2008, 09:11 PM #60
Got new P&P TB and BFG drag radials...
By PAT-LS101 in forum Drag RacingReplies: 4Last Post: 05-05-2010, 05:32 PM -
Stock Corvette ZR1 on drag radials
By trev0006 in forum CorvetteReplies: 5Last Post: 06-21-2009, 04:45 PM -
need drag radials
By tomsws6 in forum Wheels and TiresReplies: 0Last Post: 06-29-2008, 04:58 AM -
Drag Radials w/ stock rear end
By sscamaro22 in forum Wheels and TiresReplies: 31Last Post: 05-30-2008, 03:13 PM -
New MT drag radials
By Firebirdjones in forum Parts For Sale / TradeReplies: 8Last Post: 02-12-2008, 05:42 PM
