Thread: anybody put 871 on a ls1
01-15-2017, 05:58 AM #1
- Jan 2017
- S.W.FLA
Pearl white and blue- 1980
Looking to put a 871 on a ls motor .has anybody done one here ? what kind of boost can I throw at it.
01-16-2017, 10:16 AM #2
I don't know anyone off-hand using a roots style blower on this forum, but the general consensus is that 8-9PSI on a stock bottom-end LS1 is safe, assuming you are tuned properly. You'll need to upgrade the fuel pump and injectors at a minimum. I'd also suggest hardened push rods and upgraded valve springs.
I have been running that level of boost with my Procharger D-1SC for a number of years now and haven't had any issues.
I am also running a front-mount intercooler and the Alky methanol kit.Boost gets you laid, unless your name is Jon.
01-17-2017, 03:43 AM #3
I also use the Procharger D1sc and I'am running 8-10 lbs of boost on stock heads and bottom end. The fuel pump, injectors, front mount inter-cooler (or some sort of inter-cooler) and a tune are a must. Its been several years on my ride with no issues at all, pushing around 500+ hp to the wheels on 93 pump gas. I daily drive my car on 3 hr road trips, race at the track, and cruise it on "spirited" drives all the time without a care in the world. I'am also pushing 89K+ miles now. I know Edelbrock uses a "roots style" blower and have had really good success with them. I don't see why a 871 blower wouldn't work, I just don't know anyone personally that has done it.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
01-17-2017, 06:55 AM #4
Biggest issue would be fitment.
Just how tall is that blower?
You may have to cut into the cowl and even delete the wipers to make that work.
