Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    As we suffer from something called "rust" in our area, there have been some serious fights in my garage removing original parts through the years. Rusted on brake drums are probably my least favorite followed by wheel bearings mounted in aluminum knuckles. My fire wrench and BFH both see fairly regular use.
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
  2. #22
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Quote Originally Posted by bigrondownhiller View Post
    Naaman, get yourself a map gas torch, some good penetrating oil and a BFH. Between the three you should be able to get most things freed up.
    In retrospect, I really do need some penetrating oil at the very least.
  3. #23
    ^^ PB Blaster seems to work well. I am also a fan of wicking candle wax into a stuck fastener utilizing a propane torch for heat.
  4. #24
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    My father and I had to take turns hammering away on the rear brake drums of a vehicle once because we both needed to take breaks. We both know our way around a vehicle, my dad more-so than I, and we have never had to fight something so difficult. Both sides were the same. Even ended up triggering a brake light from hammering on them so much. I thought we were going to crack the casting we were hitting them so hard - with a very large hammer I will add. FINALLY, they came off.
    Upon inspection, there was literally a 1/4" tall "lip" around the inside of the drum that we were fighting against and why they wouldn't slide off. We took the hub over to the workbench and took care of that lip quite easily.
  1. Question: front suspension
    By TransAmFanatic in forum General Help
    Last Post: 02-12-2014, 06:12 PM
  2. Question: front suspension
    By TransAmFanatic in forum General Help - 5th Gen
    Last Post: 02-11-2014, 02:26 PM
  3. Front Suspension Work / Completed Rear Suspension
    By bhunter0830 in forum Suspension and Handling
    Last Post: 07-02-2013, 01:23 PM
  4. Front Suspension Work / Completed Rear Suspension
    Last Post: 04-13-2013, 05:44 AM
  5. WTB: Front Suspension
    By BlackBirdSS in forum Parts Wanted / Trade
    Last Post: 05-08-2006, 03:02 PM
