Results 1 to 15 of 15
Thread: What mod next.
    Oct 2016
    Pasadena md
    What mod next.
    I have full exhaust long tubes lid comp cam dual valve springs tooley push rods. What next. Heads?
    98 T/A w/ mods, 00 FBVert
    Depends on what your goals are.
    What size cam?
    Depending on how big of a cam a stall converter might be a better choice.
    Warning....modding leads to more modding.....it never stops...
    00 FB Vert - Stock
    Oct 2016
    Pasadena md
    Comp 231/239 617/624 113 lsa. Stall convertor on 6 speed. You can do that lol jk
    Oct 2016
    Pasadena md
    Honestly don't have any goals just moving forward. If the numbers come great.
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by Cjsmithws6 View Post
    Have you done anything with the suspension yet?
    Oct 2016
    Pasadena md
    Kyb struts eibach springs
    Sep 2010
    Bel Air, Maryland
    How about Subframe Connectors and suspension arms?
    Oct 2016
    Pasadena md
    I do not have them. Do they make bolt on kit or weld only
    Sep 2010
    Bel Air, Maryland
    They do make bolt-ons, as well as weld-ins. If you can do it yourself, or afford to have a decent shop do it, I'd recommend the weld ins.
    SLP Air Lid/Smooth Bellows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Dyno Dynamics dynoed @:
    415 rwhp
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    If you can afford it, ditch the KYBs and get some Konis. About 20 mins of research will inform you that short of a premium coil-over suspension (such as KW), Konis are the way to go for the 4th gens (I speak based on research, here; I've never experienced KYBs, myself).
    Besides that, I'd seriously think about a clutch upgrade if you're still running the LS1 clutch. My car makes around 360/360 at the wheels and I run an LS7 clutch (which we know is good for at least 505 at the crank). Also, before you start putting too much power through that crankshaft, I'd look at beefing up that T56, too. And keep the rear end in the back of your mind as something that may have to be dealt with.
    Also, what year is your car? You may be able realize some more power by bolting on an LS6 intake if you don't already have one.
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
    Oct 2016
    Pasadena md
    I'm also running ls7 clutch but it's a 01. Motor is out of a 04 goat. I have ls6 intake.
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Wait, do you mean LS6 clutch? Or, what are you referring to being an 01?
    He could be running the LS7 clutch, they have become the OEM replacement for fbodies and GTO's.
    Junior Member Last of the Breed's Avatar
    Jul 2009
    Jefferson City, Mo
    Peweter
    2002 Trans Am WS6
    A nice set of cylinder heads would do wonders for your setup. If you're on a budget, check the classified section on the LS1 forums. If you're patient, you can find a good deal on aftermarket heads like AFR, TFS, MAST, etc.
    "The Mongoose" - 447rwhp and 431rwtq
    Sep 2010
    Bel Air, Maryland
    Quote Originally Posted by Last of the Breed View Post
    The only problem doing a set of heads on a decade old engine is the possibility of finding a scored cylinder bore, or something else, if the person hadn't budgeted bottom end work.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    What is your budget? That's always the first thing to answer. Without assuming what that is, I would recommend the following mods:
    - sub-frame connectors
    - rear lower control arms w/relocation brackets
    - rear pan hard bar
    - an aftermarket torque arm which will also relocate the mounting of the tailshaft of the T56 off the torque arm (reduces the stress on the T56).
    - be prepared to upgrade the rear-end at some point if you're still running the 10-bolt
