08-29-2016, 08:56 AM #1
Need to change ignition tumbler, key getting loose hard to s
Since the key has a resistor, if I buy a new tumbler and key (w resistor) what is the sequence for reprogramming once its installed?
THANKS
Sent from my SM-N900P using Tapatalk
08-30-2016, 07:40 AM #2
You'll have to take the car to the dealership and have them marry it to the BCM.
It's costly.
You may be better off doing the VATS bypass.
08-30-2016, 07:53 AM #3
08-30-2016, 08:35 AM #4
The reason for the BCM reprogramed to the key is so it reads the correct resistance to the new key.
Yes...
http://www.ls1.com/forums/f6/how-byp...ur-vats-61262/
How hard is to change the pinion seal?
By JayTA98 in forum DrivetrainReplies: 14Last Post: 07-11-2010, 10:34 AM -
ignition lock cylinder is very loose
By camaro02sprspt in forum Computer & TuningReplies: 0Last Post: 09-21-2009, 06:11 PM -
How hard to change 160 ' T-stat? Looking f/advice
By 5abivt in forum General HelpReplies: 52Last Post: 08-14-2009, 06:41 PM -
problem getting caliper loose to change pads
By Speedy_Gonzales in forum General HelpReplies: 11Last Post: 08-11-2007, 07:08 PM -
Hard to replace an ignition switch?
By Rabbit in forum General HelpReplies: 0Last Post: 04-26-2007, 08:52 PM
